Old 09-01-2008, 10:10 PM
phxlax07 phxlax07 is offline
Rep: 10 Posts: 2
Raft out of Swimming Noodles?
Is it possible to get enough flotation out of a bunch of water noodles that kids swim with in order to support a 400 pound raft? Probably a dumb question, but it's better than PVC probably.
Old 09-01-2008, 10:23 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
I don't know but maybe cost is the biggest consideration. You've got to measure the internal volume of every type of flotatiion and rate the material at lbs of flotation per dollar. Also figure in longevity, ease of construction, etc..
Usually, the larger something is, the cheaper per pound of flotation. That would mean those toy snakes would drive you into bankruptcy. Try schedule 80 PVC (air only inside) with end caps.
Alan
Rep: 527 Posts: 792
Is this for one of those joke build competitions like the Coconut Grove Bed Race, or a sort of "Mythbusters" type of enterprise as when the boys floated a sunken vessel using ping-pong balls?
Jimbo
Old 09-01-2008, 10:30 PM
Rep: 10 Posts: 2
This is for two bored guys that desperately want to raft down a river, and are on a tight budget. We're considering ANY idea that we can find, and any material that could be found in Lowe's.
Old 09-01-2008, 10:31 PM
BHOFM BHOFM is offline
Rep: 247 Posts: 458
For safety, you could fill it with foam peanut??
To make it 4'X10' you would need 10 pieces!
About $75
each pipe is .8 cubic foot, or total of 8 cubic feet,
or about 480lbs of flotation!
If my math is correct??
http://www.lowes.com/lowes/lkn?actio...140&lpage=none
Old 09-01-2008, 11:44 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
The ultimate free raft materials are old patched inner tubes. Robust, *free*, flexible, lightweight and comfortable to sit on.
PVC will shatter on the first rock you hit at 3 knots - inner tubes will just bounce .
Old 09-02-2008, 12:02 AM
Rep: 247 Posts: 458
You can tie them together and make a decent raft and
it will float with a flat!
Old 09-02-2008, 12:17 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
Probably the cheapest NEW flotation material to build a raft out of is EPS -- expanded polystyrene -- or 'styrofoam' as it is so affectionately referred to in the USA. You can get a huge 4x4x8 foot block of it (called a billet) from a local styrofoam manufacturer relatively cheaply.
EPS comes in different densities and the lightest is also the cheapest -- and also the weakest in terms of strength -- but it floats very well and a single billet of the stuff will give you enough for an 8 foot by 16 foot raft that's a full 12 inches thick.
You'll need to put a top on it of course, which probably means 4 sheets of plywood plus a bunch of 2x4's for a framework ... and it wouldn't hurt to wrap the foam in a fishing net that's attached to the platform too, so it doesn't disconnect from the platform and float away on you as the raft flexes.
EPS is a lot cheaper than the 'pool noodles' you're talking about which are made of expandable polyethylene, so if you're at all serious about building a 'raft' instead of a proper boat maybe you should check into suppliers other than Lowe's. But if it were me, I would opt for a real boat. You can probably build a barge-type boat cheaper than a raft, and you might actually be able to control its direction better.
You could easily build this plywood dory / sampan type boat using only one sheet of 3/8 inch and two sheets of 1/4 inch exterior plywood for the hull panels. It uses a full sheet of plywood for its bottom which gives you an idea how large it is. With only two people aboard the water will not reach the 3 inch waterline and it takes a full 1100 and 1800 pounds to push it down to the 6 and 9 inch waterlines respectively.
A raft/boat like this should cost very little yet give you some real seaworthiness for contending with the big wakes tugs and other large powerboats might make. Then again if your dream is to walk around on a big deck as you float down the river, maybe you'd be better off cutting down a few trees and lashing them together instead.
Kenneth Grome
Raft/Junk Raft Building djwkd Wiki 5 03-03-2011 10:47 PM
Swimming platform lift system Alik Boat Design 30 07-26-2007 09:03 AM
Propulsion question of a different sort. Swimming Quilbilly1 Propulsion 1 03-25-2007 11:31 AM
More of a raft really... ace rockola Boat Design 7 03-22-2007 02:32 AM
the raft so far... CaptainTweak Boat Design 23 08-16-2006 08:26 AM
