Old 07-19-2006, 04:50 AM
Redsky Redsky is offline
Rep: 9 Posts: 107
R & R or new in general
im shure this has been hashed over at some point but my searches dident return any results.
given there are lots of boats out there for sale,some at quite bargian prices , rebuild a hull to suit thats already been floating a long time..wood hulls in paticular but iv seen some ex trawlers steel recently for sale at eye poping low prices in the 70-90' range real long range ocean hulls mind you,
as v noted else where im working on a couple things but id like to examin the merits of a hull already made however a lot of them seem to have short comings for whatever reason..but may have other uses if properly fitted
Old 07-19-2006, 10:20 AM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Refitting a trawler does actually require a redesign of the boat. Yanking a fish hold and refigeration units, fishing gear etc... removes a lot of weight from the boat and changes the stability and trim. If the hull is sound and you compensate for the missing equipment, you should wind up with a good boat. Most folks alter the superstructure as well, and that requires much the same kind of consideration.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 07-19-2006, 11:40 AM
Deeman's Avatar
Deeman Deeman is offline
Rep: 10 Posts: 50
fishing trawler
this maybe of interest to you, this guy bought a trawler to convert to a liveaboard. Pretty interesting..lotsa work.
http://timzim.blogspot.com/2004_12_0...m_archive.html
S&S 34 specs Skippy Sailboats 18 10-24-2007 03:43 AM
General Newb questions Searay31 Fiberglass and Composite Boat Building 7 07-09-2006 08:34 AM
Help with deadrise & co. nemo Powerboats 2 04-22-2005 03:25 AM
The General Public... Sean Herron Open Discussion: All Things Boats & Boating 0 03-31-2005 09:27 PM
Which software & when Willallison Software 5 04-29-2003 12:35 AM
