| questions regarding tahoe 19 I have several questions: 1). Can you recommend a stain that is compatible with west system epoxy? I know interlux makes a filler stain, but they said it may not work with epoxy. 2). Is there a way to test to see if the fairing is complete, or do I just use the eye and hand? 3). The side corner cap boards need to be rounded over. I don't think a router will work because it is not a right angle. Do I just do it by hand? |
| 1) I don't have experience with epoxy but in general most work, but make darn sure it is 100% dry. 2) Some use water, just wet the whole surface and it'll show imperfections. Again, has to be dry before continuing. Getting the first coat of what ever coating is used will also reveal the mistakes. The coating thing won't work if stain is used. 3) Sharp hand plane, or sanding, and taking it slowly. Maybe cut a radius (inner) template out of cardboard or plastic sheet that you use as a guide. Lurvio
__________________ Hopefully creating something useful, since 1983. |
| Olds 455 questions upon questions... | pdswerld | Gas Engines | 26 | 07-07-2010 09:36 AM |
| Questions | dmille5 | Outboards | 1 | 10-17-2009 11:42 PM |
| Various Questions | KI4NCW | Metal Boat Building | 30 | 02-02-2007 06:30 PM |
| Tahoe Q-3 2001 Lights and Fish Holding Wiring | Fes | Boat Design | 0 | 07-20-2006 07:47 PM |
| Larson bow rider versus a tahoe bowrider | constance | Powerboats | 1 | 04-17-2005 07:24 PM |
