Old 05-29-2007, 05:03 PM
hossman777 hossman777 is offline
PVC raft?
My buddies and I are wanting to build an 8x12 raft that will hold about between 1000-1200 lbs of man and beer and float relatively shallow in the water. I'm thinking of running 12' lengths of capped PVC pipe on the bottom, a few 2x4's across the top of that, and finally some plywood decking on top. Now, my questions...
*Will it work? (Kind of a dumb question, but is 1200 lbs expecting too much?
*Will a simple rudder and/or a small outboard motor work for propulsion/steering?
*Is there anything that would work better than PVC and still be fairly cheap to construct?
Any advice/wisdom/tips/etc. would be greatly appreciated. Thanks so much!
Hoss White
Old 08-02-2007, 01:48 PM
TheRiffRaft TheRiffRaft is offline
Rep: 10 Posts: 9
It will work! My buddies and I just did this. We had four of us, a table, an umbrella, cooler full of beer, four chairs, sirius satellite radio playing through a Bose Acoustic Wave radio powered by a "booster box". My estimate put us at about 1000 pounds total, including the raft. We used approx. 84' of 6" sch. 40 pvc, construction foam caulked to the plywood and secured with some 2x4's, which run lenghtwise against the outside of the PVC pipe. The foam was attached in a tounge and groove configuration to each sheet of plywood for added stability. The decking is then tied front and back to the center section of PVC. It all comes apart for transport and three of us can assemble it in approximately 1 beer. Check out the pics...
Old 08-04-2007, 11:33 AM
jrl5678 jrl5678 is offline
Rep: 31 Posts: 56
I am as strait as they come and I want to giv eyou guys a big ol kiss
that looks like soooo much fun
Old 08-04-2007, 11:52 AM
Rep: 10 Posts: 9
It was a lot of fun, and a thumbs-up would suffice. We are going to register it as a homemade boat so we can mount the engine on it and go, without being towed by the "Drunken Treasure".
Old 08-04-2007, 12:10 PM
Rep: 31 Posts: 56
true about the thumbs up
I spend 80+ hours at work, I get excited a little easy some times
so retraction
thumbs up
how will you mount the motor
what size/kind are you planning on using
and can you tell me a little more about the foam you are using
Old 08-04-2007, 12:18 PM
Rep: 10 Posts: 9
so retraction
thumbs up
We're not sure how to mount the motor yet, but I don't think it will be to complicated. We're going to use our existing Minn Kota 50 lb. trolling motor with our two batteries in parallel. There's also talk about adding some railing around the corners and lighting, but that's low priority right now.
My buddy got the foam, and I'm not exactly sure what type it is. He just refered to it as "consruction foam". Check Home Depot for the blue stuff. I'll find out what type it is and post it.
Old 08-04-2007, 12:22 PM
Rep: 31 Posts: 56
Thanks
the same kind of deck mount for a trolling motor on a bass boat should work. Seems like it would mov eyou around smartly.
Fast easy no need to clutter it up with railings and lights
if you really need lights you can get chem light sticks in white red and green once broken they last for almost 6 hours and they are 2 $ a piece more or less
Old 08-04-2007, 12:43 PM
Rep: 10 Posts: 9
Thanks
We'll most likely just fab a mount like this one....
And the talk about lights and railings was mostly drunken banter. There was also talk of a "bathroom"!
Old 08-08-2007, 04:23 AM
alaskamokaiman alaskamokaiman is offline
Rep: 13 Posts: 59
GREAT BOAT... raft but I see no life jackets.
A drunk does not revive when drowned please be safe wear a PFD and make your friends do the same it would be a bad ending to the fun we had.
Old 08-08-2007, 09:09 AM
Rep: 10 Posts: 9
Thank you for your compliment and concern.
Old 08-14-2007, 05:01 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Very very ingenious.
That's really thinking outside the box. Looking at the design I was wondering if two more sets of pvc pipes were constructed and interlaced in the manner the first three as shown on the trailer, whether the construction foam is necessary, as the original three seem to float high in the water.
Congratulations. I'm off down to Wickes.
Pericles
Old 08-14-2007, 12:00 PM
Rep: 10 Posts: 9
Pericles
The piping layout is as shown in this pic....
The pic of trailer shows how we had to load the pipe for it to fit best.
We did a "dry" run in my friends pool without the foam. With four of us on the raft water was coming up and over the wood. That is when we decided we needed to add the foam.
On a side note, we used 6 inch schedule 40 pipe only because it was free. Although we paid an arm and leg for all the connectors and caps! I would suggest cheaper 6 inch pipe. Cheers and good luck!
Old 08-15-2007, 05:19 AM
Pericles's Avatar
TRR,
Agreed. I was just wondering whether you had considered two more sets of pipes to link between the three you already have. However you also mentioned the pipes were free but the fitting and closures were expensive.
I'll let you know how I get on. I need a small raft to maintain the edges of my Koi pond.
Pericles
Old 01-15-2008, 06:50 AM
captaintrue captaintrue is offline
Rep: 10 Posts: 28
You might consider pressurizing the pipes with air a wee bit.
Old 01-15-2008, 12:26 PM
Rep: 418 Posts: 777
In this same vein National Fisherman had an article 10 years back or so about a guy who had successfully built a PVC/ RIB style boat. Using 10 or 12 inch pvc tubes (fairly spendy but cheaper than store bought) for the "inflatable tubes" and a plywood/epoxy hull. It was 25 ft or so and looked pretty good.
I always wanted to build one, LOL like that will happen.
Building a raft w/ pvc pipe? Aberamonli Boatbuilding 31 01-08-2012 11:23 AM
Raft/Junk Raft Building djwkd Wiki 5 03-03-2011 11:47 PM
More of a raft really... ace rockola Boat Design 7 03-22-2007 03:32 AM
Raft speed djwkd Open Discussion: All Things Boats & Boating 3 10-08-2006 04:07 AM
the raft so far... CaptainTweak Boat Design 23 08-16-2006 09:26 AM
