Old 09-02-2008, 12:13 PM
aka Terry Haines
Rep: 1811 Posts: 3,006
PVC doesn't float in this part of the World, SG = 1.3; ABS (SG = 1.05) might in seawater. What else was in your sink, Australian beer?
ABS is probably better than PVC, it's lighter, stronger and tougher. I think it may be stiffer as well. PVC degrades in sunlight.
Dances with Turkeys
Old 09-04-2008, 02:18 AM
alexlebrit alexlebrit is offline
Rep: 16 Posts: 122
Oh look at that, I'd never really looked at the PVC pipe in my house before, and I see it's got a foam core (well it's only for grey water) so of course it floats. I'd go for ABS though, it just seems to tear not shatter.
Then again why not a simple ply frame, I've been looking at a ply coracle on Hannu's Boatyard and it occrued to me the same basic method could be used for a canoe.
Old 09-18-2008, 09:48 AM
TheRiffRaft TheRiffRaft is offline
Rep: 10 Posts: 9
PVC will work although it's heavy and expensive. Check out the "Riff Raft".....
PVC raft?
Old 09-22-2008, 05:27 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Expensive is the main problem. I bought a metre of storm water pipe the other day, so that raft probably cost about 3 times what an all timber plywood raft with paint would have cost.
Old 09-22-2008, 12:42 PM
Rep: 10 Posts: 9
We were actually lucky enough to "aquire" the PVC for free. We did have to purchase the caps and elbows and they weren't cheap either.
Building a raft w/ pvc pipe? Aberamonli Boatbuilding 31 01-08-2012 10:23 AM
fiberglassing PVC pipe?? georgiahemi Boat Design 5 10-05-2007 06:05 AM
150mm pvc pipe jgfish Materials 17 01-23-2007 08:16 AM
Pipe-flow propulsion?? SanSan Boat Design 0 08-28-2005 06:37 PM
Pipe Rudder Bob Smalser Boatbuilding 3 02-18-2005 02:01 AM
