Old 08-10-2008, 02:28 AM
bigbear69 bigbear69 is offline
Rep: 10 Posts: 16
protection steel on the inside of an enclosed space
Hi,
I am attaching a scoop with boarding platform /steps etc to a steel hull yacht.the boarding platform will be inbuilt how do I protect the steel on the inside of this once is all welded up.
also planning on adding a overhead structure on the stern put solar panels and to hang the davits off. thinking of fabricating from steel and they will be hollow so need to protect the steel on the inside also.
i've heard of filling the enclosed space with diesel,The yacht has a diesel filled keel, is this the only way to protect the steel. or can I coat the inside before i install ?
Any help would be much appreciated.
cheers
Old 08-10-2008, 06:37 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 262 Posts: 746
Hollow structures on large ships are spray-coated with Tectyl, Waxoil or similar wax-like products by people in protective clothing and external air supply, who descend through manholes. Smaller structures are treated the same way by drilling holes in strategic places and using thin tubes with a 360 degrees nozzle head. The holes are closed afterwards with rubber plugs.
The companies that sell the chemicals also supply the equipment to apply it.
Cement wash coating for steel protection MikeJohns Metal Boat Building 30 10-08-2008 06:39 PM
16ft enclosed helm speedboat jlparsons Boat Design 9 05-12-2008 05:26 PM
Composite Steel/Wood Space frame analysis lawrencepeckham Software 21 11-13-2006 05:00 AM
Overuse of cathodic protection on aluminum or steel hulls Thunderhead19 Boat Design 6 02-28-2005 07:20 AM
Stainless steel protection on small vessel keels Gilmarine Fiberglass and Composite Boat Building 1 02-20-2005 11:51 AM
