Old 01-07-2005, 04:29 PM
Mark V Mark V is offline
Proper drain hardware?
I need to place a thru hull drain at the bottom of a 15.75 ft double ender. It will go through the deck floor, about 2 inches of air and foam, and then through the bottom or the hull. The boat is rotomolded PE.
I've looked at a variety of garboard and other drains. Any suggestions or cautions?
Thanks,
Mark
Old 01-07-2005, 09:58 PM
Arrowmarine Arrowmarine is offline
Member
Rep: 10 Posts: 107
I am a BIG believer in using a seacock whenever possible on any "thru hull" below the water line. Thats my only advice.
Peace, Joey
Old 01-08-2005, 10:07 AM
Eric Sponberg's Avatar
Rep: 2464 Posts: 1,381
Mark,
The Marelon through-hull fittings from Forespar would be very good for your application. Marelon is the plastic they are made out of, and they are very popular in fiberglass boats. They have been in production for a long time, and you can get them through West Marine.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 01-09-2005, 04:46 AM
B. Hamm B. Hamm is offline
Registered
Rep: 16 Posts: 97
If this boat wasn't designed for this I'd caution about doing it, nothing bonds well to this material. You're liable to end up with a continous leak that's very difficult to fix.
Bill H.
BassBoat Drain area, below transom rot HELP!! northrivergeek Powerboats 4 12-12-2005 08:06 AM
Bass Boat floor drain replacement hardware ? northrivergeek Fiberglass and Composite Boat Building 0 06-01-2005 10:47 PM
Discounted sources for Sailboat Hardware?? bjl_sailor Boatbuilding 0 03-16-2005 11:23 AM
Hatch locks & hardware {NW}BKUSA Materials 3 12-25-2004 11:24 AM
Sail rig hardware? Kris Boatbuilding 3 04-13-2004 08:10 PM
