Old 01-24-2007, 08:43 PM
flydog's Avatar
flydog flydog is offline
Rep: 51 Posts: 74
Progress!
Progress!-dscn0619.jpgPut the sheerstrake on and it didn't look right. I cut it too wide. I was able to cut it down after it was glued on. (fun!) Looks much better now. This is probably the steepest learning curve I've ever had on any subject. I really appreciate everyone's input and encouragement!
thanks y'all!
flydog
Old 01-25-2007, 08:55 AM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Looking good flydog. With the sheer being so visually critical to overall aestetics, I'd bet it took some time to "get it right".
My compliments on a tidy (in comparison to mine) shop!
When to do hope to have her afloat?
Take care.
TGoz
Old 01-26-2007, 06:16 PM
flydog's Avatar
Rep: 51 Posts: 74
Thanks, TIMZOZ.
I plan to launch in the early spring.
Old 01-27-2007, 11:54 PM
rstevens rstevens is offline
Rep: 10 Posts: 4
How big is your boat flydog? It looks to be about 18 foot from the pic? I've got a frame of a similar sized boat and am planning on finishing it and would love to read more about your project - as well as more pics if you have any.
[CENTER][URL="http://www.watersportforums.com"]Like watersports?[/URL][/CENTER]
Old 01-29-2007, 07:04 AM
flydog's Avatar
Rep: 51 Posts: 74
Slow Progress
My boat is a 12 foot lapstrake sailing dinghy. The material is 6mm marine-grade plywood. It is built on a mold system designed by John Brooks at brooksboats.com. If your boat already has a frame, it might be designed for carvel planking. I am no expert here, a novice at best. This is my first boat. There are many authors and boatbuilders that have addressed the subject. The only two that I have read are: Building Small Wooden Boats by Greg Rossell, and Building Small Lapstrake Wooden Boats by John Brooks. I use the second one as a building guide exclusively. If you decide to buy these books, look for them on Amazon.com. They would be cheaper than the official websites. I would be happy to keep in touch and compare notes.
flydog
Old 01-29-2007, 07:26 AM
flydog's Avatar
Rep: 51 Posts: 74
Correction
In my last post I gave an incorrect web address. It should be brooksboats.net.
flydog
Old 01-31-2007, 02:22 AM
Rep: 10 Posts: 4
Thanks flydog, I appreciate the advice. Why do you say carvel planking is better for a boat that already has a frame? (honest question, not doubting you).
Do you have anymore photos of your boat?
Old 02-03-2007, 07:08 AM
flydog's Avatar
Rep: 51 Posts: 74
Carvel vs Lapstrake
I am not an athority here. I acannot say which method of planking is best. I have only done one boat ( I have yet to finish). What I am saying is that carvel is built over frames that are put in place first. Lapstrake or clinker-built, is molded over distinctly shaped molds, then frames and or half frames are put in later to strengthen the boat. Here is a pic of my boat molds:
flydog
Old 02-09-2007, 01:56 PM
Rep: 749 Posts: 1,314
For amateur builders, lapstrake is easier, faster, and can yield a much lighter boat. I'm referring to glued lapstrake not rivet and burr methods. The down side of lapstrake is that the boat is a little noisier and more difficult to sand and paint. The laps do tend to hold the spray down somewhat,when the going is lumpy.
Flydog; it looks like you are doing a first class job. Keep up the good work.
New Guy just showing our progress... rudeman85 Metal Boat Building 6 01-28-2007 03:46 PM
Progress on Eccentricity II Thaddeus Metal Boat Building 0 05-31-2006 09:48 PM
Engine progress and price control cyclops Propulsion 18 06-20-2005 08:48 AM
Is this progress in composite construction? Mark Peiffer Fiberglass and Composite Boat Building 16 01-13-2005 11:35 AM
k-19 Strip Planking in progress. bjl_sailor Wooden Boat Building and Restoration 12 01-07-2005 03:07 PM
