Old 05-05-2002, 11:35 PM
cat chaser cat chaser is offline
Rep: 10 Posts: 5
pontoon boat
Im building a small pontoon boat (8' x 4' deck ) but Ive encountered two problems..(a) very small budget and (b) the largest pontoon material Ive been able to locate is 6" pvc.
If I use enough pvc to keep it afloat it wont be a pontoon boat, it will be a raft.
It needs to carry around 600lbs and the boat itself is guestimated at just under 200lbs. No deep water for this one, just for some slow moving river fishing and maybe some close in bank fishing on the lake. I plan on oaring it around or using a push pole.
Any sudgestions?
Old 05-06-2002, 01:02 AM
You can get 8" and larger diameter PVC from most plumbing supply companies, but it's not cheap. 20 ft of 8" PVC runs around $70-$100.
Aluminum might be preferable for weight. Have you looked at pontoon kits or are they too expensive?
Old 05-06-2002, 01:34 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
You can make some very simple pontoon hulls from plywood, lumber, construction adhesive, a few screws, and paint. If you want plans. I could try to put some lines down if don't tell anyone where you got them from.
Gary
Old 05-06-2002, 07:34 PM
Rep: 10 Posts: 5
Unfortunatly the aluminum kits are way out of my price range...have a baby on the way real soon(and the cranky wife to go with) next question...what would be the smallest diameter tubing I could get away with and not end up swimming home and what other alternitives might be available... am looking into wood but need to keep the wieght down so one or two men can manuver it out of the truck and into the water.
Thank for your quick responses and help.
Old 05-06-2002, 08:18 PM
Willallison's Avatar
Rep: 2280 Posts: 3,467
Is there a particular reason why you want a pontoon boat. A flat bottomed punt, which cvouls be built easily and I would have thought more cheaply may suit your needs just as well
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 05-06-2002, 08:58 PM
Another case for looking at something other than pvc pipe:
If my calcs are correct, then in order to support the 800 lbs total weight that you have estimated, you would need 36 ft of pipe (in fresh water). That would still only result in a pontoon which just floats. You would probably need double that in order to allow for weight changes etc. So 72 ft of pipe on your 8ft pontoon, means 9 lenghts of pipe - you still got a raft I'm afraid......
Will
www.imaginocean.net
Old 05-06-2002, 09:40 PM
Nomad Nomad is offline
Mold Trader/Boat Builder
Rep: 12 Posts: 462
The only way I can see this working is with a budget increase. Sorry man. And good luck with your kid.
Old 05-07-2002, 01:10 AM
Senior Dreamer
Cat, Will is right; it is very simple to build a small boat. Maybe even easier than a small pontoon. There are many plans to choose from. Here is a link to a boat anyone could build for under $200 US.
http://bateau.com/plans/small/FL11_study.htm
When you’re done with that one, you can move up to this one.
http://www.bateau.com/plans/misc/GP16_study.htm
I’m also working on your pontoon as an exercise for my self. It would help if I had a first name, (besides cat chaser) and a rough idea where you are from to keep in my mind while I’m working on it.
Gary
Old 05-07-2002, 07:51 PM
Rep: 10 Posts: 5
Im not realy dead set about the pontoon , but I need something stable enough to stand and toss a cast net out of. ( not fun in a small boat in the dark ...have ended up wet trying) and something stable enough to land 50 or 60 + pounds of fish.... also un-fun in the dark of night. John boats tend to skitter sideways and Ive actually been towed around around the lake in one by some horse of a fish ( I think.... never got to see it). Thanks for all the ideas so far.
Old 05-07-2002, 08:07 PM
Yep - from what you describe as the boats intended use, I'd definitely go for the punt. Blowing about in the breeze can easily be rectified by adding a couple of small keels to the boat - not only will they aid with directional stability, but they'll help protect the bottom when you drag it up the bank too
Will
www.imaginocean.net
Old 05-07-2002, 08:16 PM
Rep: 10 Posts: 5
Forgive my ignorance.... please define "punt"
Old 05-07-2002, 08:52 PM
Well, my definition of a punt is a flat bottomed boat where the sides don't narrow to a point at the bow. - a bit like this
Will
www.imaginocean.net
Old 05-07-2002, 08:53 PM
a bit of the bow seems to have vanished ther somewhere along the way but you get the general idea
Will
www.imaginocean.net
Old 05-09-2002, 10:02 PM
Rep: 10 Posts: 5
Thanks for all of you responce and sudgestions... I managed to scrounge two 10" x 10' sections of pvc from a local construction site... if Ive done my math right that should be enough to float between 500 and 600 pounds... Im going to start construction this weekend ! Wish me luck!
Old 11-03-2002, 10:33 AM
sd1359 sd1359 is offline
fiberglass pontoon
does anyone know where i can get plans for 20 ft. fiberglass pontoons ?
High-Speed Waveless Boat waveless Boat Design 82 10-10-2005 08:01 AM
pontoon boat parameters: basic sources? helipilot Boat Design 5 08-21-2005 11:29 AM
Pontoon Boat Kit Boatbuilding 5 11-04-2004 04:29 PM
