#31
| Hey Y'all I'm New at This,Can Anyone Tell Me If Block Foam 10"x12"x7' Can Hold Two People Okay?The Block Foam Is Cut From 2 Sheets Of 2"x4'x8' Plastic Foam From Home Depot I've Glued 4 Pieces Togather And Plan on Using Fiberglass Wrap on Them Afterwards. I've Also Put One 2" Pvc Pipe on The Top Inside on Both Sides To Help Make It More Rigid. Tell Me What You Think! Thanks. P.S. I've Also Started Working on A WeedWacker For Something To Push it With But Can't Seem To Find The Right Size Prop. Any Ideals? abel1955 |
#32
| Look for irrigation pvc. I'm sure you'll find what you need. |
#33
| Thanks Newbie. I've pretty much got everything done on my pontoon boat,and I have started it about 4 months ago. The good news is, it only cost me about $300.00 dollars to builded it and that's including the 34 lbs thrush trolling motor. And man it's no titanic But one thing for sure, "This Boat Is Unsinkable" I will post some pictures soon after I learn how to on this site. So you all be good and will see ya soon |
#34
| Building a pontoon boat...first time Hello, In a little less than a week my friends and i are building a pontoon boat and are planning to raft down the Niger river from the capital city of Niamey to the border of Benin, a small town called Gaya. It is about a 120 km trip (80 miles), and i was wondering if you had any experience with pontoon boats? The river is a relatively large one with a current flow of about 7mph. So far we plan to use 3 large barrels for each pontoon with a welded steel cone on one end. In between these pontoons i was planning on placing an angle iron frame and wood planks. The dimensions are about 2 and half meters by 3 meters. Thanks for the help! ![]() |
#35
#36
| Pontoons Have you considered usinging fiberglass and truck bed liner as materials to coat a pontoon? I've not tested this but I am considering using this to coat some closed cell poly foam shaped like a drum. |
#37
| Would like to build a 25ft or 30ft ponton but do not know were to start. Thank you moutianman2001@yahoo.com |
#38
| pontoon boat powers pontoon has done already what you are trying to do and it is already patented not to mention that from reading your statements your 3 years behind it in development check out powerspontoon.com |
#39
| powerspontoon.com check out powerspontoon.com you'll see what your looking for |
#40
| compressed air for floatation Just mentioning, I have used 8 inch dia on a small single person peice of crap that I build eons ago. BUT I first drilled a 1/4 inch hole in the cap of one end, added a valve stem with epoxy, and pumped -if I remember right- about 20-25 pounds of air in each side. It ended up holding my pregnant self at about 180 and 2 small kids on it with all of our picnic and fishing stuff with relative stability. Any one who has kids will know how much crap is required to take em out for a couple hours! Then the kids got big (like I TOLD em not to but did they listen?) and I gave the thing to my nephew who continued added another seat to use it with his wife. Just an idea for you to consider...my hubby thought I was nuts but it worked ... |
#41
| Replacement rails for pontoon boat. I'm restoring a pontoon boat and it needs new rails. I've seen some sites that do this but it's almost 1000 1300 for a full set of rails. Anyone have any good ideas? |
#42
| Hey Y'all I'm New at This,Can Anyone Tell Me If Block Foam 10"x12"x7' Can Hold Two People Okay?The Block Foam Is Cut From 2 Sheets Of 2"x4'x8' Plastic Foam From Home Depot I've Glued 4 Pieces Togather And Plan on Using Fiberglass Wrap on Them Afterwards. I've Also Put One 2" Pvc Pipe on The Top Inside on Both Sides To Help Make It More Rigid. Tell Me What You Think! Thanks. P.S. I've Also Started Working on A WeedWacker For Something To Push it With But Can't Seem To Find The Right Size Prop. Any Ideals? 360 lbs to top of foam for fresh water. (5.8 cu ft x 62.4 lbs/cu.ft. disp) 370 for salt water. (64 lbs disp/cu.ft.) Try a replacement prop from a trolling motor. Steve |
#43
| Cool story Scott I would love to see a photo. If you would email me a picture Ill host it on my server and people can click the link to see it. webmaster@texaswarlord.net I have been interested in something similar and would very much like to see the foamula 1 Thanx Tex |
#44
| Could you design other boats? Quote:
Gary,just wondering if you could design other boats and possibly e-mail them.please replly to this with your answer. |
#45
hey!you could change your name to 'fish chaser' then or 'catfish chaser'! |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| How about boat design definitions | JonathanCole | Boat Design | 48 | 04-18-2006 06:49 PM |
| High-Speed Waveless Boat | waveless | Boat Design | 82 | 10-10-2005 08:01 AM |
| pontoon boat parameters: basic sources? | helipilot | Boat Design | 5 | 08-21-2005 11:29 AM |
| Pontoon Boat Kit | Boatbuilding | 5 | 11-04-2004 04:29 PM | |
