| Plywood Yacht Material MORNING ALL QUICK QUESTION ABOUT COVERING MARINE PLY WITH EPOXY ..... AM CURRENTLY BUILDING A 8M YACHT FROM MARINE PLY AND PINE AND WANT TO KNOW IF THE BULKHEADS I AM BUILDING NEED TO BE COVERED WITH EPOXY WHEN THEY MOVE OUTSIDE TO BUILDING STOCKS OR WOULD A UNDERCOAT OF PVA DO. SOMEONE MENTION MIXING ACETONE WITH EPOXY AND COVERING BULKHEADS THAT WAY ? REGARDS COLIN FARROW |
| Hi Colin your questions have been covered many times on this forum, search a little and you will come up with a ton of info, i have also written about epoxy often. Firstly tell us a little more about yourself, where are you and what are you building, what experience have you with what - a little background info Quote:
building a 8m boat is a **** load of work free plans mean nothing - worse still there is very little backup in russian. i have checked and i worry about what i see, it makes me think of a clever designer that takes of like a rocket and when the money doesn't flow like a river there is no more backup or updates on the website, just a couple of grainy pics there is no point in using inferior materials
__________________ Bye bye Folks - off to see the world ~~~/)~~~ :) Compulsive Neurotic Manic Depressive, but basically happy :) http://compaxboats.wordpress.com/ http://www.boatdesign.net/forums/boa...ser-27869.html |
| First of all, it's much easier to read your post if it is not all caps. Building stocks, braces and other project related, but not part of the boat structure elements, do not need to be coated with anything, unless your project will take several years to complete, at which point paint will be fine. Elements going into a plywood boat should be encapsulated, not just coated with epoxy. That is every surface, every screw hole, every notch or cut out is coated with neat epoxy. If you assemble, then coat, some areas will not be completely covered, defeating the reason behind using this technique. Do not mix acetone with your epoxy, unless you have a chemical engineering degree, of which you can rely on, to support your alterations of the epoxy molecule. |
| epoxy and plywood Thanks to all who responded and for the english lesson I have limited exsperience in boat building besides stuff i have down loaded Have sailed on a dam in south africa called vaal dam and am sure manie B would know were that is. Have started building a kavalier k800 that russian one and have made about 4 of the 15 bulkheads and am quite happy with detail of plan i have but would appreciate all input i could receive cheers colin |
| Colin where are you - town city dorp village ??? i would like to know more about how you ulitimately see the build it is a very bold and "adventurous" step to build the russian boat dont get me wrong - i am not trying to knock you or the boat i went over the plans a couple of times and there are some tricky bits i dont think it is a simple build - its on the difficult side, precision will be important anyway go for it and enjoy
| germiston by the sea Morning manie live in a town called marlands thats in germiston. Was a bit concerned when i first saw plans but after studing am a lot happier about the build. Have very good wood working skills and am a qualified sparky and am pretty good all rounder. Haved received and downloaded tons of photos wich also eased my mind so let the fun begin. cheers colin |
| Q: How to create a single curved surface in Rhino for Plywood planked Yacht Tender | JAK | Software | 6 | 06-02-2009 03:17 PM |
| Newbie here with newbie question. Marine plywood or plywood? | photojunky | Wooden Boat Building and Restoration | 30 | 07-23-2007 06:41 AM |
| material help please | madmatt | Fiberglass and Composite Boat Building | 4 | 12-02-2006 02:33 PM |
| boat material / furniture material | bogeyinthekeys | Materials | 7 | 09-10-2005 09:29 AM |
| Plywood material properties | Archive | Materials | 2 | 06-12-2001 05:01 AM |
