Old 08-21-2010, 01:30 AM
ThomD ThomD is offline
Rep: 98 Posts: 375
Plywood joint CAD file
Has anyone created a CAD file for an interlocking joint in ply, for a jig. A lot of CNC cut kits these days come with some kind of wave pattern, or dovetail pattern for joining ply together. I've got all kinds of scarf capability in the shop, but there are cases where an interlocking joint would be structurally adequate and easier to build out. Before I settle down and draw something up, I was thinking someone may have already done it. The idea would be to get it cut in aluminum, and use a bearing bit to blow out the parts.
Rod & Reel CAD file S Hondros Powerboats 5 08-31-2011 11:22 PM
Plywood Scarph Joint Ratio Meanz Beanz Wooden Boat Building and Restoration 78 04-14-2010 10:40 AM
Sandwich hull panel to plywood bulkhead T joint??? leegrace Fiberglass and Composite Boat Building 4 02-01-2006 08:42 PM
Convering .hul to cad file - is it possible? Rasman Boat Design 12 06-13-2005 10:00 PM
series 60 lines / CAD file DaveB Boat Design 0 08-09-2004 02:12 PM
