Old 11-10-2011, 03:02 AM
tsanakou tsanakou is offline
Rep: 15 Posts: 7
plywood and foam sandwich comparison
Somewhere I have seen a comparison of plywood thickness and foam sandwich thickness. Don't remember where.
Has somebody an idea?
Tsan
Old 11-10-2011, 05:45 AM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
I can give you one data point. 9mm of okoume is roughly equivalent to 3/4", 5lb foam with 34 oz skins.
"You can't solve all of life's problems with epoxy" - My Wife
Old 11-10-2011, 07:39 AM
Rep: 1493 Posts: 7,447
It depends on the type of plywood and foam. Gerr's book addresses sandwich construction in an easy way.
Old 11-11-2011, 01:22 AM
Rep: 15 Posts: 7
CatBuilder: thanks for the data;5lb foam though seems to be very light.
gonzo: Gerr's 'Boat Strength', chapter six is referring to cored constructions, but doesn't compare it with plywood.
I am quite sure that I have seen a spreadsheet about that somewhere, but I dont recall where. Will keep searching.
Thanks for your help! Tsan
Old 11-11-2011, 05:30 AM
groper groper is offline
Rep: 307 Posts: 382
You do realize you are trying to compare apples with oranges dont you?
Regardless, this might help you - http://www.atlcomposites.com.au/file...uflex-foam.pdf
It shows a comparison of a 600gsm glass laminated 20mm thick, 80kg/m3 foam sandwich with plywood, aluminium, steel and solid glass... its a shame the comparison is not of equal thickness`s to give a better idea of the strength vs thickness in materials...
So, the 13mm plywood is already twice the weight of the 20mm foam sandwich and its only 1/6 the strength... you could extrapolate this very roughly by following the rule of thumb - strength proportional to thickness squared, stiffness porpotional to thickness cubed and re work the numbers for 20mm plywood if 13mm ply = 5mpa then 20mm = 11.83mpa. compared with the foam sandwich of same thickness with 600gsm epoxy/glass skins 62-64% fibre content (so infused or prepreg) = 30mpa... you get - roughly 1/3 the strength in plywood of the same thickness and 3 times the weight.
Old 11-11-2011, 07:25 AM
Doesn't matter if you think it "seems light" or not. Those two item (9mm of Okoume) and 5lb corecell with skins of 34oz on each side are equivalent in terms of load carrying ability.
Old 11-11-2011, 03:47 PM
Rep: 307 Posts: 382
No way cat builder, i find that impossible to beleive... when you refer to the 5lb/cu.ft corecell thats A500 3/4" or 19mm thick right? that density is around 80-90kg/m3 yes? 34oz glass on each side = 950gsm, assuming its a stiched fabric and not CSM etc. - would give a MUCH stronger and MUCH stiffer panel than a tiny 9mm of okume plywood by an order of magnitude.
Old 11-11-2011, 06:31 PM
rberrey rberrey is offline
Rep: 69 Posts: 287
Cold mold =CM
Single fiberglass skin=SFGS
SFGS ,single skin refers to hulls that are built up of fiberglass laminations only,no foam.
Formulas, cold mold plywood to foam sandwich construction.
A: Ratio 1 CM to .66 SFGS. B: SFGS x 2 = core thickness C: .7 of SGFS = Total FG laminate. Example using two 1/4" plywood skins, equaling 1/2"plus the glue and fiberglass hull cover of say 1/16", which gives .25 + .25 + .062 = .562" of CM.
1. (A) Ratio 1 to .66, or .562 x .66 = .376 SFGS
2. (B) .371 x 2 = .742, or 5/8" or 3/4" core thickness
3. (C).7 x .371 = .259" total laminations thickness.
4. .259 divided into two surfaces = .129" thickness of fiberglass laminate per side.
The conversinn formulas here are not to supersede your designer specifications. Formulas are presented as a guide only. Formulas may be on the heavy side as they are oriented to the use of mat and woven roving in the layup. This is taken from Ed Horstman,s book Foam Fiberglass Sandwich Construction. I cant type fast so thats all you get . Buy the book it,s well worth the money and time spent reading it. Rick
Old 11-12-2011, 05:47 AM
[quote=groper;500676]No way cat builder, i find that impossible to beleive... when you refer to the 5lb/cu.ft corecell thats A500 3/4" or 19mm thick right? that density is around 80-90kg/m3 yes? 34oz glass on each side = 950gsm, assuming its a stiched fabric and not CSM etc. - would give a MUCH stronger and MUCH stiffer panel than a tiny 9mm of okume plywood by an order of magnitude.[/QU
Those panels, excepting stiffness, are interchangeable on the desing I'm building. I have a data point here. The op says the corecell is too light. You say its much stronger. Which of you is right?
Old 11-12-2011, 12:08 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
Hw can the corecell be "too light"? He must mean something else.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 11-12-2011, 03:37 PM
Rep: 69 Posts: 287
Using Ed,s forumulas I came up with 5/8" foam for 3/8" ply, so 3/4" foam for 9mm is about right, maybe a little oversized . We dont know the desighed stress loads or any other factors taken into consideration when the designer converted the scantlings from ply to foam. I,m sure the designer had a reason to call for 3/4" foam. In Ed,s book ,rule of thumb , approx pvc core- 41' to 50' boat length 3/4",FRP thickness- .290, 51'to 60' boat length pvc core 3/4", FRP thickness .350. Length of Cats boat may be one reason the designer calls for 3/4" foam. Bottem line most of us are not NAs or designers, we are lucky there are some and we all know they dont always agree. Designing or converting your scantlings on your own is risky and maybe costly. Rick
Old 11-12-2011, 06:19 PM
Rep: 307 Posts: 382
Gentlemen, i think i can see the problem here...are we referring to using ply as a core material or plywood on its own? I think this clarifies the point....
Which begs the question, Catbuilder, does your data point specify the same thickness of glass skins for both types of panel, foam and ply?
Old 11-12-2011, 06:56 PM
In smaller boats, wood produces a stiffer panel unless you are using some exotic laminates. People that go from wooden boats to fiberglass often complain of the spongy feeling of decks and the give of the hull.
Old 11-14-2011, 06:40 PM
Sand crab Sand crab is offline
Rep: 23 Posts: 66
Not exactly what you are looking for but interesting nonetheless
http://www.westsystem.com/ss/compari...of-flat-panels
http://nida-core.com/english/nidapro...comparison.htm
Old 11-14-2011, 06:54 PM
It specifies a lighter skin on the ply, mostly for protection from impact damage: DB 1708 or something like that, along with the 9mm of Okoume.
These are the hull panels used on the boat I'm currently building... it comes in two flavors - ply/epoxy/light glass or foam/glass.
sandwich method for subsequent foam replacement ? gabdab Boat Design 3 10-14-2008 07:20 AM
flat panel foam sandwich stregenth pescaloco Fiberglass and Composite Boat Building 5 08-18-2007 11:40 AM
25 yr old foam sandwich constructed sailboat jksoft Fiberglass and Composite Boat Building 3 07-27-2007 08:30 PM
Composite foam board sandwich technique scottperkinsusa Boat Design 11 09-18-2004 08:30 PM
Homebuilt: Plywood vs. sandwich Slowmo Materials 22 09-06-2004 03:39 PM
