Old 11-14-2011, 08:04 PM
Charly Charly is offline
Rep: 271 Posts: 209
Originally Posted by CatBuilder View Post
It specifies a lighter skin on the ply, mostly for protection from impact damage: DB 1708 or something like that, along with the 9mm of Okoume.
These are the hull panels used on the boat I'm currently building... it comes in two flavors - ply/epoxy/light glass or foam/glass.
but the foam version does not have stringers
Old 11-14-2011, 08:15 PM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
That's right, it doesn't. Some extra stiffness there.
"You can't solve all of life's problems with epoxy" - My Wife
Old 02-26-2012, 09:18 AM
tsanakou tsanakou is offline
Rep: 15 Posts: 7
I found it: http://multihullblog.com/2010/11/ply...th-comparison/
Kurt Hughes on Catamarans, Trimarans, and Boat Design
Plywood/Glass strength Comparison
How strong is glass compared to plywood? Here is a table comparing strengths with out of plane loads (like water pressure).
Plywood/Glass Thickness Conversion comparing bending strength. (Assumed 60,000 psi bending strength for glass and 10,000 for plywood)
Assumed that triaxial amount is on both sides of a core
Ply thickness Triaxial thickness Core
3mm ply equals (12 oz) 400 gsm w/12 mm core
4mm ply equals (17 oz) 600 gsm w/12 mm core
6mm ply equals (22 oz ) 750 gsm w/12 mm core
9mm ply equals (34 oz) 1150 gsm w/19 mm core
12mm ply equals (2) (22 oz ) 1500 gsm w/19 mm core
Old 02-26-2012, 09:29 AM
Cough. Cough! ahem! Look at the second post in this thread. Agrees 100% with what tsanakou and Kurt Hughes posted.
Old 02-26-2012, 10:11 AM
Rep: 15 Posts: 7
I wonder:
9mm ply equals (34 oz) 1150 gsm w/19 mm core = weight of foam = foam 1.52kg/sqm + 2X ( 1150 gsm + matrix 1150gr) = 6.120kg/sqm ???
The plywood is 5.2kg/sqm + 220gsm + 220gr matrix = 5.64kg/sqm ???
Does that make the plywood construct lighter?
Old 02-26-2012, 10:32 AM
It does, but to compare more accurately, you must investigate the method of construction off the cross beams and include stringers, as 9mm ply needs stringers for stiffness.
There is a reason Kurt's cylinder mold boats are among the best performing of their kind in the world. It is a very light way to make a boat. Look at his personal trimaran (now sold and in Europe). You can't do much better than that.
Lastly, a big surprise for me was that the Kurt Hughes I'm building has better weight numbers than the carbon fiber Gunboat 48, even though the lwl is the same and the KH is beamier. (gunboat 48 is a 45 where they count the bowsprit for loa)
The man knows how to make a performance boat without blowing your budget.
Old 02-26-2012, 11:37 AM
david@boatsmith david@boatsmith is offline
Rep: 50 Posts: 85
well I am not an engineer but I have built boats of 3/8 (9mm)plyand am now building a boat of 1 1/2 oz CSM, 1708,1808, with 5/8 H60 and 1708,1808, 1 1/2oz CSM. I do not consider a 3/8" ply to be anywhere near as stiff or as strong as the sandwich.
Boatsmith Inc
We Build Your Dreams
(561) 744-0855
www.boatsmithfl.com
Old 02-26-2012, 12:41 PM
Rep: 15 Posts: 7
Well, I am happy that I found the comparison again; there are doubtlessly better production methods than the plywood method. But when it comes to prototypes it is still unbeatable for my humble opinion and it is still fun to work with wood.
I am glad that groper wasn't that right with his post: 'You do realize you are trying to compare apples with oranges dont you? ...compared with the foam sandwich of same thickness you get - roughly 1/3 the strength in plywood of the same thickness and 3 times the weight...' I am happy to compare apples and oranges when there is a good reason for it ;-)) Thanks for all your help!
Old 02-26-2012, 01:09 PM
Corley Corley is offline
epoxy coated
Rep: 524 Posts: 624
Its worth keeping in mind that you can bag core to the inside of a ply structure as well instead of stringers to help with panel stiffness you get some of the positives of both methods then.
  #25
Old 02-26-2012, 01:20 PM
Rep: 15 Posts: 7
Composites have a big variety of methods available; we have constructed a very light proa with a much smaller size of plywood thickness demanded because we were using Aramid/Kevlar from the inside and glass from the outside. Everything is possible ;-))
  #26
Old 02-27-2012, 11:11 AM
idkfa idkfa is offline
Rep: 66 Posts: 232
Catbuilder, somehow 9mm equals 21mm (19+1+1)?
I might be hesitant betting against 9mm solid carbon.
  #27
Old 02-27-2012, 11:21 AM
What are you talking about?
The OP asked about foam/glass laminates and how, in an engineering sense, they compared to plywood.
I responded in the 2nd post of this thread that 9mm ply is equivalent to 1150g/80kg-19mm foam/1150g.
There is no discussion about solid laminates or carbon.
sandwich method for subsequent foam replacement ? gabdab Boat Design 3 10-14-2008 07:20 AM
flat panel foam sandwich stregenth pescaloco Fiberglass and Composite Boat Building 5 08-18-2007 11:40 AM
25 yr old foam sandwich constructed sailboat jksoft Fiberglass and Composite Boat Building 3 07-27-2007 08:30 PM
Composite foam board sandwich technique scottperkinsusa Boat Design 11 09-18-2004 08:30 PM
Homebuilt: Plywood vs. sandwich Slowmo Materials 22 09-06-2004 03:39 PM
