Old 12-16-2005, 07:23 PM
sandman1984 sandman1984 is offline
Rep: 10 Posts: 4
Plug and mold construction
I am having trouble figuring out how plug and mold construction works...I cant really find any sites with pictures of the whole process. Right now i am doing stitch and glue construction and would like to move up to molds (maybe?) for production. If you know of any helpful links please let me know. Thanks!
Old 12-17-2005, 04:12 AM
nero nero is offline
Rep: 112 Posts: 624
search this site for "strip planking". This is one way of making a plug and can be used to produce a mold also.
Old 12-23-2005, 05:42 PM
jonsailor jonsailor is offline
Boat designer/builder
Rep: 31 Posts: 38
Depending on the design type and shape, we have had good results from MDF (custom wood panels) used as a mould surface. View my website www.sayerdesign.com and it gives a bit of a run down on some methods.
This should not be considered if you are looking into a lot of boats to be released but is economical for maybe 5 or so.
Old 12-23-2005, 08:08 PM
tja tja is offline
Rep: 11 Posts: 125
tja
For example you take a hull that you designed in stich and glue. Finish off the outside of the hull to finish. Apply release wax to the outside of the hull. Gelcoat, layup with fiberglass to desired thickness. Let cure. Separate form original hull. Wax new mold with release, gelcoat, layup glass and reinforce, cure, and pull new boat. That's it in a nut shell. It's not rocket science. But the guys that do this for a living as I do know that there is quite a lot more to it to do the job right. If you really want to learn how to do this get a job at a boat manufacturer and pay attention to the details. Like I've always told my kids. Because of that there all better educated and smarter them myself. Good luck. Tom.
Plug Construction and post cure. ClarkT Fiberglass and Composite Boat Building 3 08-19-2005 01:37 AM
Foam/Plywood boat plug construction ?s cla17 Boatbuilding 22 05-21-2005 03:44 AM
Help Wanted Design, Plug, Mold and Builder Cpt Albert Fiberglass and Composite Boat Building 7 07-01-2004 06:45 PM
Help Wanted Design, Plug, Mold and Builder Cpt Albert Boat Design 0 06-28-2004 09:55 AM
Foam / Plywood Boat Plug Construction ?s cla17 Materials 2 05-18-2003 07:45 PM
