Old 03-24-2010, 08:04 AM
gaurav.p.shinde gaurav.p.shinde is offline
Rep: 10 Posts: 2
Planning on building a Dudley Dix design
hey guys,
i have started a sailing school in India(www.pelicansailingschoolmumbai.tk) so that more and more people get to sail for very small costs. our school is offering beginner and advanced courses at costs as much as 120$
we are planning to build are own yachts instead of buying them. it would save us a lot of money and effort of getting through customs, duties of which are very high for imports into india.
i have gone through the Dudley Dix designs and find that the Didi26 matches our requirement for training.
Do you think it is worth it to train in a Didi26?? would it be a good option?
if u can help me with better options if u think so, let me know
secondly i want to build one yacht for myself with which i can sail to maldives, muscat, UAE and africa from Mumbai... which designs do you recommend. i like the Didi 40cr... wat do you think?
any tips and suggestions other than this are welcome...
Old 03-24-2010, 06:22 PM
Sam III Sam III is offline
Rep: 46 Posts: 71
I have not built the 26, I am in the process of building a Didi Mini 21 and think the build is very straight forward. I used a cnc cut kit to speed up the build and found the building instructions were very good.
Dudley supports the build after the sale of plans.
A 26 foot boat is a reasonable size for instructions.
Sam
Note: Truth in commenting, I am a CNC Kit Cutter for Dudley in the United States. But I was a Dix customer before I started the business.
__________________________________________
We build Mini's www.thirdcoastcomposites.com
Old 03-25-2010, 11:18 AM
Rep: 10 Posts: 2
hey how and where do i source mast boom and sails for the project?
Old 03-25-2010, 06:45 PM
Rep: 46 Posts: 71
I sourced my mast and boom from US Spars in Florida. I am sure you can find someone closer than them. Look in New Zealand or Australia.
Same for sails.
Sam
Old 03-29-2010, 08:51 AM
GDFL GDFL is offline
Rep: 28 Posts: 14
If you need small and easy to build maybe take a look at origami construction. There are plans for some smaller boats that would fit your needs and they are geared towards cheap and fast (to build)
Old 04-08-2010, 07:51 PM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
I purchased the Didi 38 plans and then upgraded to the Didi40cr. Dudley was extremely helpful and encouraging as I modified the plans to suit my requirements. He prepares an extremely detailed and well thought out set of plans. I ended up buying a completed hull from a bankrupt builder, but only because it was a great buy and mirrored the design philosophy found in the Didi line. I don't think you'll go wrong with the Didi 26 and I know first hand that Dudley provides superior support to amateur builders. I say go for it.
Old 04-14-2010, 04:04 AM
rugludallur's Avatar
rugludallur rugludallur is offline
Rugludallur
Rep: 235 Posts: 81
Go for it
I'm currently building a Dix design from steel and I have been very impressed with the detail and practicality of the design.
I think building your own boat is a great way to learn but make sure your cost and time estimates are realistic, if you just need a boat it's usually less expensive to buy a used boat but then you don't know exactly what you are getting and might need to spend a lot of money refurbishing it.
Jarl Stefansson
jarl@dallur.com
http://dallur.com
Old 04-14-2010, 02:23 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Originally Posted by rugludallur View Post
but make sure your cost and time estimates are realistic....
Even us pro's get it wrong most of the time
What size Dix are you building? I agree on you on the plans and Dudley and I were good friends when he still resided in South Africa before moving on to the USA.
Had built a few of his boats; 38ft (I commissioned the design in 1991), 43 ft centre cockpit, 57ft and 65ft. In fact, the 65ft on his web page was my built and the 57 is also feature on his web page floating on the water.
Dix does support his plans till the boat is built. Cannot think of another designer doing that unless there is monetary gain. The reason his plans are complete and builder friendly is due to his hands on approach. He built a few of his designs himself in the past in his back yard and raced them successfully.
Wynand
A scatterling of Africa
Old 04-14-2010, 04:22 PM
Rugludallur
Rep: 235 Posts: 81
Probably seen it before but ..
Hey Wynand,
It's a HoutBay 33 and I have been documenting the whole thing on http://dallur.com
The gallery is already pretty big and I have a few videos including a time lapse from the webcam which I will release once all steel work is done.
Jarl
jarl@dallur.com
http://dallur.com
Old 04-15-2010, 12:03 AM
Wynand N's Avatar
Jarlm, good choice and that is the boat I would have build myself. Affordable and simple.
In fact, my last boat to be build would have been a Houtbay 33 but since the build could only started 3 months after I completed my last boat, I opted for retirement from boatbuilding and now have time to spend with my grandson, fishing and just lazing around
Wynand
Dudley Dix "Hout Bay 30" jcjglt Sailboats 2 11-21-2008 07:43 PM
Dix design Cat razor Multihulls 2 08-14-2007 09:42 AM
DUDLEY DIX-Didi 40 Sly Sailboats 23 04-26-2007 11:56 PM
Design of Planning Boat chinemaster Boat Design 2 02-13-2004 04:13 PM
The Application of Design Planning Control in Shipyard Robotics Scott Education 0 11-20-2001 08:16 AM
