| Thanks guys! I just placed an order for the epoxy from Clark Craft. I'll definitely spread epoxy on the screws before driving them in. That was an awesome tip. I'm thinking of taking my Dremel to the pilot holes a bit so the screws will seat deep enough that I can spread wood flour/epoxy over them in order to "seal" them in while at the same time providing a nice smooth look when sanded, stained or painted. That might be overkill however, which is one of my tendencies. ![]() And Catbuilder... If you pitched in for airfare, I'd probably take you up on your offer if you lived near the coast. ![]() Edit: The text of the plans indicate to use 1/2" x 1 3/4" carriage bolts to secure the frames together at the chine corners, and 1 1/2" flathead screws at the keel/floor frame. The large carriage bolts would sure be more substantial than the smaller screws I was considering using, but of course wouldn't (I don't think) hold the soft pine frames together without a lot of tightening/denting of the wood. Thoughts? |
| Don't increase the fastener size thinking you'll have a stronger boat. All you'll do is make the boat heavier. If you're using epoxy where the plans are calling for marine glue, you'll have a stronger structure where the fasteners are acting more as clamps and may become secondary to the glue joint itselt. That being said though, try not to stray too far from the plans. Your boat was designed to be held with mechanical fasteners and random application of epoxy may not blend well with this more traditional style of construction. I've always like the appearance of Petrel and will be eager to see your progress.
__________________ LP ---------- God bless the open minded people of the world. LP |
| You may want to just bung the holes rather than epoxy the heads in. If you ever have to take something apart you will have to drill out the screws if you cover the heads with epoxy. You can't get it out of the bit holes. |
It's really going to be fun to post progress pics. You guys will have to let me know when you would like to see pics of any aspect I don't cover very well; I'm a pic junkie, so it's fun for me! It's also extremely helpful for me to have you experienced guys watch everything that I'm doing so if I do anything crazy you can let me know. Lol Wow, that is an excellent point. If I do indeed use screws, I will definitely bung them in rather than cover them w/ epoxy. Thanks! |
| Actually, bunging is a pain in the butt, just epoxy them over and I'll tell you why. Bungs fall out, raise up and need to be carefully installed. If you need to remove a screw under thickened epoxy, just heat up an appropriate tipped screw driver (one you don't like so much) with a blue tipped wrench, until it's glowing red. Then push this, hotter then a hooker, out side a GM plant on payday tip, into the epoxy over the fastener head. The red hot tip will melt right through the epoxy and you can easily engage the slots. If you left the red hot tip on the screw for a few seconds, the heat will also soften the epoxy on the threads, making twisting it out a piece of cake. The softened epoxy will come out with the fastener head and the hole process is uneventful. Naturally, you don't want to touch the shaft of the heated screwdriver. The only time I bung (unless I'm drinking heavily), is on surface that will be brightly finished and that are thick enough to receive a bung. 3/8" is about as thin a material as you can use for bungs, while still having sufficient meat under the fastener to effectively hold it down. |
| Par, I love your descriptions of things. ![]() I went to the hardware store yesterday to find stainless steel carriage bolts. I got into a conversation with an employee there who really questioned me as to why I'd used carriage bolts rather than traditional nuts/bolts. He was saying that the carriage bolts could pretty easily strip and spin over time and could be a pain to remove; especially in the soft pine frames I'm using. Thoughts? I now have 3 sets of frames cut out. I'm just waiting for the epoxy to arrive before I start assembly. I feel kind of like it's Christmas already! |
| Boat Building Insurance??! | CatBuilder | Boatbuilding | 3 | 05-02-2010 04:12 PM |
| Boat builder's insurance? | BigCat | Fiberglass and Composite Boat Building | 2 | 08-17-2008 08:59 AM |
| boat insurance | silver23 | Metal Boat Building | 4 | 06-18-2004 07:12 PM |
| Wood boat Insurance | alanagr1 | Open Discussion: All Things Boats & Boating | 2 | 05-29-2004 06:16 PM |
| Boat Insurance | JenoQ | Services & Employment | 0 | 05-01-2002 12:17 PM |
