Old 07-28-2011, 01:24 PM
RoyPilent RoyPilent is offline
Rep: 10 Posts: 7
penny headed rivets
got me an old 12' Sears,Roebuck canoe that Im redoing, the gunwales were riveted with a penny rivet, dont know if any one has seen this but I would like to replace them back when I get the gunwales done. Can I buy them or use solid copper rivets and drill the penny ??
one other thing what is the best way to remove tar from fiberglass??
Thank You
Last edited by RoyPilent : 07-28-2011 at 01:41 PM. Reason: sorry posted in the wrong place
Old 07-28-2011, 01:54 PM
Rep: 749 Posts: 1,314
Google copper rivets. There must be a supplier someplace.
Several methods to remove tar. If it is thick, try ice bags to make the tar as cold as you can make it. Sometimes it will peel off. Worth a try. Mineral spirits is a solvent for most tars such as Blackjack, If that does not do it fast enough then laquer thinner will do it. Mineral spirits is the safer and cheaper choice. In either case keep any flame of sparks away from the wet solvent and the rags that you use.
Old 07-28-2011, 02:16 PM
Rep: 3125 Posts: 9,395
Are you sure it's tar, as it could be butyl rubber, which is a common sealant found on older 'glass boats, particularly under the deck cap flange.
Old 07-28-2011, 02:19 PM
Rep: 10 Posts: 7
on the rivets most of what I found was for gutters, I may have to go another route,
with the tar someone tried to fix some leaks not good but want a safe way to remove so it dont mess up the glass, thanks will try the ice even though it only 101* here lol
Old 07-28-2011, 02:20 PM
Rep: 10 Posts: 7
Yeah its tar like roofing tar.
Old 07-29-2011, 06:50 AM
Rep: 10 Posts: 7
I could peel most of the tar off to find a crack in the side right on the curve of the bottom so it looks like I get to do my first fiberglass repair, did some reading and the u-tube thing and think its doable will, use the solvents to remove the rest of the tar film, still cant find the penny rivets so might need to go with something else there but still looking.
Thank You for the help
Old 07-29-2011, 08:02 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
You may be interested to know only old pennies are solid copper. New ones are copper-clad zinc.
Hoyt
Old 07-29-2011, 08:29 AM
Rep: 10 Posts: 7
Thanks, didn't know that I'm thinking of finding something else ?? will be looking to see what I want/can do with the rivets. Just thought the penny's were neat and wanted to go back with them.
Old 07-29-2011, 06:02 PM
MatthewDS MatthewDS is offline
Rep: 43 Posts: 101
Copper rivets are here:
http://www.jamestowndistributors.com...d+Copper+Nails
Jamestown has several types besides the rose head, but I like the way they look, and that's what I use.
Regarding the pennies, if you must use them, punch the holes with a Whitney punch rather than drilling them. It's so much easier.
Otherwise, flat washers used to make rivets are called burrs, and conical washers are called roves. Both are available at the above link.
One who furrows the sea enters into a union with happiness - the world belongs to him, and he reaps without sowing, for the sea is a field of hope.
Old 07-30-2011, 06:01 AM
Rep: 10 Posts: 7
Thanks for the link, I see what your saying burrs/ roves, the nail look like what came out of the canoe now I know what to get when I go to replace them copper nails and penny burrs. I will use the holes that are there bight be a pain but what the hell.
Thank you for the help and info
Old 08-02-2011, 09:58 AM
Rep: 10 Posts: 7
Got the tar off with the help of W-D 40 worked well messy but clean up with dawn now to patch the crack, seen how its done step by step on youtube, I think I can do this.
A friend has some Brazilian wood for me will be picking it up today but it is 9' long, canoe is 12' so I will need to splice it for the cunwales, want to use it for the woven seats, yoke and decks. but I need to do something with the keel, Build it up or what? will look more into this seen the bed liner thing, and rope thing, I think that would look bad.
Another friend has some teal green auto paint and clear coat ??? I like free but will it work for my canoe?
Thanks for every thing
Replacement Rivets Cheapshot Metal Boat Building 1 04-19-2010 02:27 AM
Aluminum Rivets silverslayer Materials 7 02-17-2008 12:37 PM
Red Headed Neanderthals Pericles Open Discussion: All Things Boats & Boating 4 10-27-2007 11:33 PM
Difficult project (for me) aluminum foil (3.5 cmx 3,5 cm) needs to hold up a penny jephman Boat Design 5 11-19-2005 07:19 AM
removing rivets nighthawk Boat Design 2 04-19-2005 09:17 AM
