  #61
Old 01-04-2012, 06:07 PM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Originally Posted by DriesLaas View Post
Just a quick pic of the complete PD racer hull kit.
It goes together with a little fitting ( you have to file out the fillets left by the round cutter. I can remove it with the router, but then you are left with a slightly larger cutout than absolutely necessary.)
It looks very promising at this stage, I will try to start assembling over the weekend.
The plywood we got is quite dense and stiff. It is about 750 kg/m^3, and the hull kit weighs a hefty 40 kg (88 pounds) of plywood mass.
What is this weight normally? If it is grossly overweight I must try to save some mass elsewhere.
If your boats come in at around 100 lbs, they are not that exceptionally heavy. Some in the fleet are much lighter, but those were made lighter due to lighter wood that was readily available and at relatively low cost. One I designed dispensed with the air tanks altogether and replaced them with one gallon milk jugs. But weight was added in other areas, such as an elevated cockpit sole, and it ended up weighing (on paper) 125 lbs.
I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute.
  #62
Old 01-04-2012, 11:57 PM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1474 Posts: 1,620
I went thru my old records and the 9mm ply that I got from the same supplier was around 14 to 16 kg per sheet
this 6mm is heavy BUT from what I saw it is really good quality
batches do vary but the material that you have there is going to build some REALLY fine boats
on all the edges that I inspected there were no voids or overlaps
I was very impressed with the marine ply
now that I have slept over it
I must say that a well designed and cut kit like this one is fantastic
I think that it could be assembled as is
join all the pieces together with epoxy glue
cover all the surfaces in epoxy
FINISHED
no extra wood - no fillets - no glass - nothing extra
the plywood is very stiff over such short distances
and the finger joints makes this a very rigid construction
ulitimately Dries will have THE BEST PDR kit available in the WORLD
In my childhood days I was a very keen "Airfix" model aeroplane builder, all the WW2 planes. I had many of these planes hanging from my ceiling, and with a gentle breeze blowing thru the room it was magic to lay on the bed and dream of flying away on one of these little planes swinging on a piece of cotton thread.
Some of the guys here will remember those "kits" - everything in one box. You had to carefully break each part out of a framework and the glue the pieces together.
That is what this PDR kit is all about, glue the pieces together and you have an instant boat. This system works so well that I firmly believe that much bigger boats could be built this way. The key factor is that you have to have a 100% detailed CAD drawing. Not only did Dries draw PROPERLY he really pulled this one off. Top job!!
Bye bye Folks - off to see the world ~~~/)~~~ :)
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
  #63
Old 01-05-2012, 07:46 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Calling Manie and DriesLaas;
Now that the design and prototype is done, please refer to post #24
Nice work gentleman.
Wynand
A scatterling of Africa
  #64
Old 01-05-2012, 08:39 AM
Manie B's Avatar
You can definately have one
but the "donation" is kinda
shall we say
oh what shall we say
oh dear
f@rkit dunno bout dat
anyway keep you posted
  #65
Old 01-06-2012, 01:08 PM
Stoffeltoo Stoffeltoo is offline
Rep: 10 Posts: 13
Hi Dries, Manie
My boat weighed in at 50kg exactly with two 7" side air boxes. I used 4mm for the sides and 6m for the bottom and deck.
Man and now I have that terrrrible itch again.
I want to build a 16' tacking proa, ama and lateen sail, the works.
I even built a balsa model 1:12 scale this afternoon, see pics below
I am besotted with boat design, where is it going to end?
PD Racer South Africa-06012012394.jpg  PD Racer South Africa-06012012395.jpg  PD Racer South Africa-06012012397.jpg
  #66
Old 01-15-2012, 12:59 PM
DriesLaas DriesLaas is offline
Weekend Warrior
Rep: 39 Posts: 39
I am afraid the only known cure to this affliction is to buy a large screen TV and watch copious amounts of mindless sport, like blue bulls rugby for example.
After a while the stupidity permeates into the brain of the watcher, and tends to stifle strange tendencies towards creativity.
Beware however that your innocent remote control should not inadvertantly stumble onto eighteen foot skiff racing in Sydney Bay Harbor, or some VOR racing footage.
If this should happen, I humbly suggest giving in to the urge, opening Fundamentals Of Yacht Design on page one and locking yourself in the garage. Because you are lost to mankind.
  #67
Old 01-15-2012, 05:23 PM
JRD JRD is offline
Rep: 137 Posts: 108
Its OK, relax - Beer can fix this part! But you just need enough to get past the point of believing you are about to redesign the eighteen foot skiff or VOR70.
  #68
Old 01-16-2012, 10:24 PM
Rep: 10 Posts: 13
Beer I have plenty, time, I have little of.....Dreams of a selfbuilt boat too much. Lying awake at night with visions of boat structures and frames is overwhelming. So I suppose that I will be opening the purse strings soon. The plan is to build two eight foot polistyrene Ama's coated with poxy and glass, then at least take a polyprop plastic kayak sailing
  #69
Old 02-01-2012, 11:11 PM
Manie B's Avatar
Hi Dries
how are you
any news on the PDR
  #70
Old 02-09-2012, 05:47 AM
Weekend Warrior
Rep: 39 Posts: 39
Hi Manie,
Nothing to report. The hull panels are stitched together, and then I was overtaken by more pressing matters.
Should get back to building next week.
Regards,
  #71
Old 02-16-2012, 02:54 PM
Angélique's Avatar
Angélique Angélique is offline
aka Angel (only by name)
Rep: 1004 Posts: 583
Thanks for clarifying that, it had me going as well.
It could have spared me the trouble to think it out if I'd found this page earlier
BTW Manie, when in tow as a dinghy behind the Micro, isn't the PDR's bow transom gonna pound in a chop . . ? ?
Cheers,
Angel
  #72
Old 02-16-2012, 02:57 PM
Angélique's Avatar
Hey Dries, next week is now, how's the build going, did you find time . . ? ?
Good luck !
Angel
  #73
Old 02-17-2012, 12:07 AM
Manie B's Avatar
I spoke to Dries on the phone and he is SNOWED UNDER with work
at least somebody is very busy
PD racers in South Africa Manie B Wooden Boat Building and Restoration 3 11-16-2008 07:24 PM
South Africa vs The world Manie B Boatbuilding 6 09-08-2008 03:22 PM
South Africa around the island Manie B Boat Design 8 02-04-2008 12:24 PM
CATIA in South Africa CDC_Catia Software 0 01-08-2007 06:07 AM
need help with weather page mainly us and south africa neptunenet Open Discussion: All Things Boats & Boating 2 12-10-2005 07:06 PM
