Old 11-16-2009, 03:10 PM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,539
Paints
Gents Fanie and i have just had some lousy results with an expensive 2pack epoxy paint
This question is a little different
how many of you have experimented with "different" paints that may be "cheaper" this is for boats THAT LIVE IN THE WATER AT SEA
this is to paint over polyester and glass AND over epoxy and glass
in other words a "normal" fibreglass boat AND a "normal" ply and epoxy boat
In our country we are been fed a bucket of ******** by a bunch of wankers that know fu3kall - they are called "paint experts" = thieves
what i am after is actual experiences of paint jobs that were done with normal or domestic commercial exterior enamels and or exterior PVA's
the guys in the boat yards are using the "cheap ****" and i am not sure what they are using, in a small diminshing market like ours everything "boat" is TEN times the price
Duckworks and those chaps are forever experimenting with good results BUT those boats mostly live on trailers, and i am trying to establish a good paint schedule even it means touching up every two years or that extra coat
any titbits will help
Bye bye Folks - off to see the world ~~~/)~~~ :)
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
Old 11-16-2009, 03:14 PM
Rep: 1397 Posts: 7,215
I paint my boats with oil base house paint. People that think it is not good, routinely leave their houses in the weather with several years between paintjobs. For the interior I use exterior latex house paint with mildewcide. It stays clean.
Old 11-16-2009, 04:20 PM
wardd wardd is offline
Rep: 443 Posts: 925
http://www.angelfire.com/nc3/davecarnell/
http://www.angelfire.com/nc3/davecarnell/articles.html
Old 11-17-2009, 12:11 AM
Manie B's Avatar
Thanks guys that is what i have been looking for
this is a very good read
it is just unbelievable that when you tell those bastards that you are building a boat they treat you like you have a peanut for a brain
in my country 80% of people that sell anything "boat" are absolute wankers
Old 11-17-2009, 01:37 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
Manie, I regularly repair and paint boat hulls and mostly are power boats that takes a beating and never had a comeback or bad result. But remember, paints are only as good as its preparation.
For example, spent 3 weeks prepping a Z craft invader cat and the painting the hull and deck only took an hour flat - looked a million dollars though when done.
For starters; you have two choices of paints in SA. Firstly, Glatex which is the best but hard to colour and limited in colours. It is a 100% pure polyurethane paint and excellent, but its nemesis is sun and it tends to fade pronto pronto.
The paint that I use is 2K (poly-acrythane) and can be mixed into any colour you like. This is and excellent all rounder and Transnet uses this on trains and most cars are painted with this nowadays. It is extremely resistant to UV rays and keeps its shine.
Best to buy a good brand of 2K - one that uses 50% mix to 50% hardener ratio. But as said, paint is only as good as its preparation.
This is how you should go about: Firstly, sand down the poly or epoxy surface until smooth - flat down with water sand paper until you down to 2000#. Clean thoroughly, apply primer. ONLY use MX spray primer/filler - cream colour. (remember the plug of the L6 when we pulled the mold - that's MX). It is usually a 1:4 ratio hardener to paint. The grey automotive primer commonly used it not compatible with K2 epoxy paints and the result is paint that shrinks, crack etc.
Let it dries thoroughly again and sand down with 1500 - 2000# water sand paper and clean. Now you ready to spray on the 2K and have fun.
Wynand
A scatterling of Africa
Old 11-17-2009, 02:32 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Boxy Fisher Catamaran
Thanks Manie, there you have it. I will later check how tough the glatex is but I plan to replace it with 2k.
Regards
Fanie
Water ! Just gimme water !
Old 11-17-2009, 03:35 AM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
Paving ....
Have had good luck with Paving paint for the decks....
I used this brand :It lasted for 10 years on a deck on a boat kept outside in all manner of weather, was still good when I sold the boat.
Epoxy / glass / ply deck , I think I applied 3 coats , then masked off and sprinkled granulated cork to make anti - slip panels. Looked good.Very hard wearing.
Bondall Paving Paint is formulated with a polyurethane modified alkyd resin and added slip-guard. This product provides a tough hardwearing film with good abrasion resistance and excellent durability. It is It is ideal for use on driveways, paths, carports, warehouse
and garage floors, timber decking and boat decks. primarily intended for use on concrete floors, but can also be used on brick, stone and timber if required.
Old 11-17-2009, 04:11 AM
Manie B's Avatar
Wynand thanks for the input but there is NO WAY that i spend all that time and effort on a "paint finish"
i MUCH prefer the PAVING paint - much closer to my "style"
Old 11-17-2009, 04:47 PM
The boat show finish is not for boats that see a lot of service. They are toys with more time being serviced and polished than sailed.
Old 11-17-2009, 05:48 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1782 Posts: 2,982
At least we don't holystone the decks, anymore.
Old 11-17-2009, 06:53 PM
Fanie's Avatar
Fanie
Thanks Wynand, the MX spray primer/filler - cream colour is a good hint. I will go visit the local shop and see what it looks like (yea, I know cream coloured )
I don't want the boat to look like a show piece, but whatever I paint the boat with must at least not make it look like junk.
Regards
Fanie
Marine Paints amateur mariner Boatbuilding 4 03-17-2009 10:50 PM
Paints, Topcoats, Above/Below Waterline, Fiberglass/Aluminum ChrisN67 Boat Design 1 12-31-2008 06:33 PM
BOTTOM PAINTS - Wearlon and other new paints naturewaterboy Materials 17 02-24-2008 06:24 PM
50% off Sterling paints, primers, reducers... JR-Shine Marketplace 0 01-22-2007 10:45 AM
Sprayable paints.... TBarCYa Materials 11 04-22-2005 12:22 PM
