Old 03-23-2008, 11:27 PM
philzero44's Avatar
philzero44 philzero44 is offline
Rep: 10 Posts: 13
Painting an old aluminium boat
I have an old painted ally boat that's in bad need of a repaint,but after talking to people about using one pack or two pack paint I'm not to sure what to use.I was wondering has any body painted one lately.Thanks Phil.
Old 03-24-2008, 01:13 AM
Previous Member
Rep: 0 Posts: 0
sand it heavily, with power sander if possible
Acid wash it, then when dry apply a heavy coat 2 pack epoxy undercoat , something like altex number one, you can shove on as much as you can afford in one hit if you have a decent gun
Then you can either just spray on a finish, three times around 20 mins in between, with 2 pac, altex or if you want a job thats perfect and does not chalk for 12 years interspray linear urathane at 100 a litre , bloody robbing retailers OR you can spray a one pack oil based high glosss house paint over it
providing it is very clean forget the acid wash
Old 03-24-2008, 07:33 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Yep, lazeyjack has it right, as it is an old boat, do not waste time and money sandblasting etc etc, just do the best you can and accept that it will be OK for only a linited time. The 12 years is quite true for the paint, but I doubt it will be sticking to the old alloy for that long.
I did a Fisher 25 dive boat about 18 years ago, but did it correctly (again with Altex and linear poly) and it still looks very good today.
Old 04-03-2008, 10:56 PM
philzero44's Avatar
Rep: 10 Posts: 13
Has anybody heard of epinamel hb primer and salcomix 603 top coat thanks Phil
Boat Painting Cost 75HUSTLER Boat Design 11 10-12-2006 12:24 AM
Boat painting questions.... futuresweets-10 Fiberglass and Composite Boat Building 27 06-04-2006 09:26 PM
painting a fiberglass boat questions revshot Fiberglass and Composite Boat Building 3 02-12-2006 04:43 PM
Re-painting old bass boat Rayb Boatbuilding 5 07-11-2005 07:50 PM
Boat maintance/Painting business Trout Slayer Materials 1 02-01-2005 12:36 AM
