Old 06-13-2004, 08:08 PM
zember311 zember311 is offline
Rep: 10 Posts: 16
Paint question over epoxy
Hi everyone.
I have been using 635 epoxy over fiberglass on a hull i have been working on. Itis the epoxy from Us Composites.
My wife is going to paint some art work on the hull once it is ready, but what paint will stick to this epoxy?
I can build the boats, yes.
But know NOTHING about paints, hence the reason why I use pigment dye in the epoxy, hehe.
I am under the idea that epoxy is almost close to the plastic family, I know there is a new paint on the market called Fusion, which is directly developed for plastics. would this work?
thanks in advance for your help
kyle
Old 06-14-2004, 11:04 AM
lprimina lprimina is offline
Rep: 35 Posts: 103
I dont know if it will work but they do make paints for epoxy...
Now if the fusion works let me know
Old 06-14-2004, 03:26 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
You can get pigmented epoxy (gelcoat) in a wide variety of colours.
Old 06-14-2004, 05:51 PM
ErikG's Avatar
ErikG ErikG is offline
Rep: 339 Posts: 397
AFAIK the pigmented Epoxy still can't replace gelcoat, as it's sensitive to UV (sunlight). Or have advances been made?
Old 11-25-2004, 08:08 PM
Alsek Alsek is offline
Rep: 10 Posts: 2
Fusion is made by Krylon and will stick very well to slipper plastics with low surface tension. It may work fine but I would test it first. Epoxy cures quite hard and is easily painted after using a conversion primer. You need to wash any blush for the cured epoxy, sand it, wipe it clean and prime it with an epoxy primer. I use PPG DP-40 which you can ovber coat with anyhting. Interlux also makes an epoxy primer.
Old 11-26-2004, 03:22 PM
Phil Locker's Avatar
Phil Locker Phil Locker is offline
Rep: 49 Posts: 84
Info on one epoxy gelcoat can be found here:
http://www.wessex-resins.com/proset/gelcoats.html
I hear they're trickier to work with than the vinylester/polyester gelcoats, but can't say from personal experience.
As for painting over epoxy, I do it every week... personally I start with an epoxy primer over a well cured & sanded epoxy surface.
Phil
Competition Composites Inc. / Phil's Foils
www.fastcomposites.ca
Topsides & Deck Paint Question Chris Krumm Materials 3 08-27-2005 08:44 PM
Easier way for balsa core deck replacement? pago cruiser Boatbuilding 4 06-01-2005 07:20 PM
epoxy question, zember311 Boatbuilding 5 05-23-2005 12:38 PM
Paint System For Epoxy Hull VIKING Boatbuilding 5 02-02-2005 04:02 AM
Help PAint or gel this is the question Bayliner bum Materials 1 09-10-2004 01:37 AM
