Old 05-05-2003, 03:53 PM
chris_crawford chris_crawford is offline
Rep: 10 Posts: 2
Paint and Putty - Please Help
Hello, I've been working on a small John Boat that I designed with the Hulls program, and I just realized that I may have a BIG problem on my hands.
When I bought my wood and started on the boat, I didn't pay much attention to the type of plywood I was using. I chose some Oak ply because it looked nice and was free from defects. I now realize that this is interior plywood, and I believe the center of it is actually some type of composite rather than solid wood.
Is there a type of paint that I can use which will protect and water proof the wood? Maybe an epoxy or fiberglass paint?
Also, what is a good filler to use to fill in places where I removed screws, screwed them in too deep, or didn't quite get the cuts in my wood to match up?
This is my first boat to build, and it's defiantly been a learning experience. Thank you for your help.
-chris crawford (chris_crawford@yahoo.com)
Old 05-05-2003, 05:41 PM
Hi Chris,
Have you thought about covering the whole boat with a layer of fiberglass cloth (using epoxy) for durability and to waterproof?
Old 05-05-2003, 05:53 PM
Rep: 10 Posts: 2
I have not thought about that. Where can I find more informatin about this method? Thanks -chris
Old 05-05-2003, 06:14 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
Chris,
Here is a few sites for epoxy and sealers. If you already have the wood cut then I would have to agree, glass it, inside and out.
http://www.epoxyproducts.com/marine.html
http://www.raka.com/index.htm
http://www.masepoxies.com/mas11.htm
http://www.westsystem.com/webpages/p...uide/index.htm
http://www.rotdoctor.com/products/product.html
Gary
what to use for filler? smoothing before paint LKJR Boatbuilding 5 08-25-2004 09:16 AM
