| outboard as an inboard? I am new to boating...but i was wondering if most outboard engines are water cooled, and if so could one be used as an inboard... The purpose for this is that i find most outboards approximately 60-65 hp to be cheaper that inboard of the same power... My plan was to take the motor... mount it horizontally and have the driveshaft lead to the prop below the boat...usual mounting procedure for an inboard... Any advice on this, if it is possible would help me out a bunch, thanx guys. |
| Genius? You are either a genius or out of your mind. I can't decide which. |
| ob inboard mounting, shaft, hullfittings and hoses, venting etc has still a better price? need smal high tech block it would be, i dont know what to say... |
| cooling? Guess my first question is a little out there.... can someone tell me if outboards are water cooled... maybe the rest i can try and figure out on my own. Thanx |
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| I think so, yes. I belive they pull the water thru the ports on the lower unit so if you replaced that with a drive shaft, rerouting the plumbing would be an issue.( If I'm wrong someone help me. Builder not a rigger :-) The mercury sportjet line uses an outboard powerhead to drive the jet, so I guess it is possible. My question is with the exorbitant cost of outboard motors these days is it really cost effective? Not to mention the terrible fuel economy. (fourstrokes not included) Its been a while since I made any comparisons but I think a new 60hp merc is about $4500 as opposed to a 355hp GM ZZ-4 crate motor V8 at around $3800/ V-6 about $2900 @ 250hp. Of course there are a lot of other factors that could even things out, I.E. weight to hp ratio, Fuel economy, ease of application, servicing(who will work on it when it breaks down) boating application. etc. etc. Mercury's sportjet has a voracious fuel appetite. On the other hand, you might be on to something. Inboard jets are really performing these days, but 200 hp outboard bass boats are hitting 90 mph. Dont outboards leak when layed over past a certain angle. Or is that just my '67 Evinrude:-)Who Knows. Good Luck, Joey |
| What Inboard? So the whole outboard as an inboard was a bad idea... but can someone suggest a cheap inboard...if that is the cost effective way to do it... same 60-65 hp for an old wooden runabout type of craft? It's a pretty small craft about 14 and a half ft. Thank you. |
| Why not a conventional outboard mounting? |
| This is an interesting topic. I have wondered if I could find a water cooled 40-60 hp gas engine that could be mounted in the cosole of a skiff, fitted to a jet drive. I havent been able to find a small v-twin (or other) liquid cooled engine over 35 or so hp. |
Thank you for the advice |
| Inboard to outboard conversion | James Francis | Fiberglass and Composite Boat Building | 16 | 06-28-2007 02:46 PM |
| Inboard to Outboard conversion | Crishinor | Propulsion | 4 | 06-15-2005 12:05 AM |
| Inboard to outboard conversion, need help with details. | bradmc | Boat Design | 1 | 05-11-2005 11:10 PM |
| Converting inboard to outboard | RobCEW | Boat Design | 7 | 10-28-2004 03:20 PM |
| outboard vs inboard | duluthboats | Option One | 29 | 02-24-2004 07:34 PM |
