Old 07-22-2005, 06:58 PM
nemo nemo is offline
Naval Architect
Rep: 137 Posts: 132
One-off plug building question
Hi,
I designed a boat that will be built one-off. I'm not much into this kind of construction, I know the procedure but I have some doubts about the making of the plug.
The frames of the plug will be cut with a cnc router, and I figure out I have to subtract the hull thickness from the station, to give a correct dxf file to the cnc router. And what about longitudinal wood strips on the plug, how far should I put them from each other, transversely?
"water always knows better"
Old 07-23-2005, 05:24 PM
Rep: 1397 Posts: 7,216
What material is the hull going to be built of?
Old 07-24-2005, 04:07 AM
Naval Architect
Rep: 137 Posts: 132
Fiberglass/Epoxy
Old 07-24-2005, 04:13 AM
Naval Architect
Rep: 137 Posts: 132
I mean..solid glass for the hull and sandwich for the deck.
Old 07-24-2005, 12:40 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Originally Posted by nemo
Hi,
For a new design one-off, making a plug and a mold might not be the way to go. The time, money and marerials of a one use plug and mold could be expensive, with no guarantee the boat will be any good. Depending on the shape of the boat, a one use mold might be easily and rapidly constructed of cheap materials or a boat made more or less directly, with say c-flex, and all the time spent fairing a plug could be spent fairing the boat, and most of the materials in a fiberglass mold could just be used in a fiberglass boat. Sam
Old 07-24-2005, 01:09 PM
If you are making a male mold, it has to be completely planked. Fiberglass molds can't have gaps.
Old 07-24-2005, 01:48 PM
Naval Architect
Rep: 137 Posts: 132
Wait, I think we're going far from the thing I asked
Ok, I'll do a male mold.. the thing I wanted to know is how should I take into count the thickness of the strip plank when I draw the frames that have to be cut with a cnc router..
Old 07-24-2005, 01:50 PM
If you were referring to my post above, I was thinking of that 1/8" masonite smooth surfaced 'tile board' stuff from 'Home Despots' for around $11 for a 4x8' sheet. With Bondo in the corners and a few coats of wax it works very well and depending on the construction of the mold will last for multiple uses. As mentioned it depends on the shape of the hull, as to what you can use for a mold. Re-reading your post though, I think you weren't addressing me, as I was talking about a direct female mold.? Sam
Old 07-24-2005, 05:04 PM
The thickness to be substracted has to be perpendicular to the surface of the planking. That is, it varies as the angle of incidence of the planking changes with respect to the framing.
Hull enlargement question?? jackason Boat Design 3 09-09-2005 08:03 PM
Questions on plug building... Pavook Fiberglass and Composite Boat Building 8 09-06-2005 02:42 AM
Plug Construction and post cure. ClarkT Fiberglass and Composite Boat Building 3 08-19-2005 01:37 AM
building mold and boat from scratch need help marbleman Fiberglass and Composite Boat Building 6 08-08-2005 12:16 PM
Fiberglass hull building question Sgray Boatbuilding 2 01-27-2003 02:48 PM
