| oi moter support repair whats the best way to repair the part around the moter on my io 305 chevy boat the moter is starting to sit a little tilted from the rott on that moter support is there a name for that part thanks. ![]() |
| Is it a fibreglass boat? How old? If so, a motor that size would usually be mounted one of these ways: lag bolted to a pair of glassed-in engine bearers, through-bolted to metal brackets which are through-bolted to the stringers, or (gasp!) lag-bolted to the stringers themselves. Could you post some photos?
| rotten engine cradle the moter is lag bolted to the stringer i think it definatly lag bolted but on the down side the moter mount is crushed down about an inch and the pull sid looks fine thanks. |
| yes it is a fiber glass boat and were the moter mounts to the floor of the boat on the down side the mounting area is crushed down about an inch thank you again. |
| Ruraint & long tail moter? | plymouth | Open Discussion: All Things Boats & Boating | 5 | 12-05-2010 08:44 AM |
| Transom Support | James Francis | Fiberglass and Composite Boat Building | 2 | 06-09-2006 08:24 PM |
| transom support | James Francis | Boat Design | 0 | 05-29-2006 12:09 AM |
| Do I need the mast support? | Gregor_L | Sailboats | 4 | 05-11-2005 05:38 PM |
| stringers and support | strandedturtle | Materials | 0 | 07-02-2004 12:02 AM |
