Old 04-21-2011, 09:21 AM
barrow_matt barrow_matt is offline
Rep: 10 Posts: 9
Oar Design
I have just got a 10'6 rowing boat, 4'6 beam minus a set of oars. having looked online the cost seems excessive so I plan to try and make my own.
I would be interested if anyone has any tips or advice regarding design, materials and size. I'm looking to row reasonable distances for up to a few hours and at sea if that makes much difference.
My initial thoughts are around 8ft long, pine shaft with a slightly curved plywood blade (macon style). And a decent coat of exterior varnish.
I'm not sure about the blade dimensions, 5-6" at the tip, tapering up?
Old 04-21-2011, 10:17 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,849
I just made an oar the other day 40mm square Merranti (cost 2 quid) and triple 40mm at the bottom. When the epoxy dried I used a 4inch grinder with a 16 grit disc and 1/2 hour later I had an oar.
The 16 grit disc was like cutting butter with a soldering iron. I had never made one before and it was simple--simple.
Oar length etc is all on the internet. Americans call it a paddle!!!
Old 04-21-2011, 05:48 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
Americans know the difference between an oar and a paddle! Paddle is what you do to your 'ore!
http://en.wikipedia.org/wiki/Paddle
http://en.wikipedia.org/wiki/Oar
Hoyt
Old 04-21-2011, 07:16 PM
Carteret Carteret is offline
Rep: 122 Posts: 106
Frosty is dead on. I made mine the same way.
Those 16 grit discs can really carve!
Here is a location for a set of plans.
http://www.duckworksmagazine.com/06/...oars/index.htm
Old 04-21-2011, 08:01 PM
Frosty's Avatar
Im making a modification to them today. I have bought some cheap 45mm internal dia fishing line rings. Those cheap red and blue things that you keep a handline on.
Instead of the leather wrapping I intend to Sikaflex these hand line rings where it wears in the oar locks which I made yesterday.
The rings snap onto the oar locks which are made from 9mm stainless steel in a horse shoe shape and a stem welded on, small holes at the bottom of the stem were drilled in 1/8 for key rings as locks.
The oars will not jump out of the oar locks but with a good tug they will.
Bending 9mm on a 6 inch vice on the dock was not easy.
Apart from the boat rowing like crap the oar mechanism is fine.
homemade oar rickjames Boat Design 14 06-28-2009 05:10 PM
restoring a painted crew oar gtviet Wooden Boat Building and Restoration 3 01-07-2009 09:21 PM
Oar Locks & Seats Maine Rookie Boat Design 5 07-16-2006 10:41 PM
