Old 03-02-2010, 01:00 AM
superfellow superfellow is offline
Rep: 10 Posts: 5
Novice Needs Advice
Hello guys!
I'm new to the world of boatbuilding, and I am looking to set up shop. As a first project, I am wanting to make a small (~8ft) strip-planked rowboat.
Although I am eager to hear any advice any of you guys might have, I am also new to woodworking and was curious as to what size table saw I will really need for this (and future) boatbuilding endeavors.
Thanks!
Old 03-02-2010, 05:08 AM
missinginaction missinginaction is offline
Rep: 417 Posts: 336
I wouldn't go crazy about a saw at this point. I've restored my 27 footer with a 10" saw and found it adequate. Look for a saw with a decent rip fence and as large a table as you can find. As you actually work with wood you will encounter situations where you'll say "I wish this saw had this or that feature" and if you really like boatbuilding you might buy a more expensive saw in the future. Depending on where you'll be working portability might also be an issue so consider how much it weighs. I'm sure others will weigh in but $200 - $250 should get you a decent saw and there are plenty of sites where you'll find reviews. You might also consider buying a roller outfeed support so you won't have to call your wife to hold long pieces of wood that you feed through the saw. Wives generally hate this! At least mine does.
A couple of other things to remember. Get a good blade, which usually means expensive. You'll thank yourself. And lastly be sure that you can install a dado blade into whatever saw you buy. Dado blades are very handy and you'll probably learn more about dados as you go along.
MIA
Old 03-02-2010, 07:33 AM
Rep: 10 Posts: 5
Thanks for the advice MIA!
Old 03-02-2010, 09:13 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
I've always seen the table saw as the foundation of the workshop. Therefore, my recommendation is a bit more pricey than MIA's. $500.00 would be bare minimum. Ideally, you'd have a saw with wheels (Rigid (Home Depot) makes one--- 10" cast iron in the price range mentioned).
Cast iron has heft and usually cast iron saws have trunnions and a seperate motor/belt drive. They are also usually convertable to 240 volt, and are very quiet (those little aluminum saws scream).
However, I'll admit that you can make strips on any table saw with the right jig.
Old 03-02-2010, 10:49 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,682
You don't even need a tablesaw. A saw like this is easy to make....
http://www.youtube.com/watch?v=AkWgzAk0kuQ
Drill a small hole in each corner of the saw base. Do a plunge cut on a piece of plywood, then unplug the saw. Use sheetrock screws to secure the saw, and then wire the trigger "on". Turn the plywood over, screw or nail to sawhorses, break off the sheetrock screws, grind flush if needed. Put a straight stick or level up against the sawblade and mark both ends on plywood. That is zero, measure from those marks for width of cut, clamp strait stick or level at marks, plug in the saw and cut.
Old 03-02-2010, 05:41 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
All good advice. Follow safety precautions. Think ahead. If you cut off anything you are not supposed to, make sure your driver knows the quickest route to the emergency room.
Hoyt
Old 03-02-2010, 06:10 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
superfellow,
Your choice of boat design is a good one, it will teach you many processes and conventions.
Take your time, learn that quality does take time and you will be better off in the long run (it takes time you see).
Do not take short cuts in known methods, they have already evolved to be pretty good. If you do see some way to improve on something, maybe ask here again to see if others agree, who knows you may change the world, and even f you do not, you will end up with a boat that you can be proud of, and that is all that matters.
I see many people try stitch and glue for their fiirst boats, waste of time. Do it right and do it once, you will learn REAL boatbuilding that way.
Old 03-02-2010, 08:53 PM
Scott Carter's Avatar
Scott Carter Scott Carter is offline
Rep: 143 Posts: 130
Please don't make your own table saw. The reasons are mostly obvious safety concerns, but from a practical standpoint even a $100 second hand saw of ANY make is going to be better than something you cobble together. Plus, you still have to put a saw into a home made saw, right?
A 10" shop-grade table saw is certainly everything you need. 99% of even the commercial cabinet and boat shops out there have them. They're ubiquitous. A larger industrial grade 12" saw is for a shop that does lots and lots and lots (and lots) of cutting all day every day, or handles large timbers that require the depth of cut.
A cast iron (or granite - Ridgid's new saw) table will go a long way in keeping your work and the saw itself steady. But also a large table extension (shop made is fine) is a luxury you'll be thankful for time and again. There are lots of plans on the inter-webs for making your own table extensions out of melamine faced MDF (smooth surface), or even just plain old plywood. At a minimum, a pair of very steady (read broad base) roller out-feed supports. You'll want two if you don't have a large out-feed table because a sheet good could be in two large pieces once it comes through.
As mentioned, invest in a high quality (usually = expensive, $80-$100 minimum) carbide blade. It will pay for itself. A rip blade isn't absolutely necessary, a combination blade handles most jobs adequately. But a rip blade will definitely be appreciated if you're doing a lot of ripping (like making your own strips).
Brand-wise, you'll do very well with a Delta saw, and Ridgid has come on very strong in the larger tool market. They put a lot of thought and quality into their tools. Fine homebuilding does tool reviews often, and recently they did one on portable table saws.
I would encourage you to find a second-hand saw. They just don't wear out. They get scratched and maybe the cabinet gets dented. But old saws are old for a reason, because they were built well. A good, new Uni-fence (Google it) and a high quality blade will give any saw a new lease on life.
Good luck, and happy building.
Old 03-02-2010, 10:11 PM
Landlubber's Avatar
....once upon a time, in another life....I sold machinery.....a question often asked is why buy second hand, new is almost as cheap if you buy Chinese (etc)....new must be better than old....well, my response to the question, buy new lathe or old was, what made the new lathe?....
...don't be afraid to purchase old machinery, it is often of a better quality than the new stuff.
Old 03-03-2010, 12:54 AM
Itchy&Scratchy's Avatar
Itchy&Scratchy Itchy&Scratchy is offline
Rep: 117 Posts: 141
Excellent Landlubber, thank you - a man after my own heart.
Im forty - thats somewhere between young -ish and old!!(duck for cover...)
Ive finally learned to look for old tools, a lot of mine are antique tools which I bought on Fleabay. Buy a new set of chisels and use them and then go looking for an old set of marples chisels and once sharpened the difference is significant.
Old planes, chisels etc go for nothing. I am currently looking for a scroll say, not the elcheapo rubbish you can buy in stores but the old foot powered jobbie,I mean they are still available and work beautifully, whers as fifty years down the line, the cheapo will have been in the bin for forty five years alreadyat least.
Have fun
Itchy
Im working on my second million.........I gave up on the first!
Old 03-03-2010, 01:03 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
if you want to see tools in action and I see you are in the US look for New Yankee Workshop on your tv channels ...Norm will teach you more in one programme about wood working tools than all the verbal advice in the world .
Note ..I just googled it and you can watch on line ....gives you the programme scedules etc
Old 03-03-2010, 01:47 AM
Landlubber's Avatar
pistnbroke,
that is an excellent site mate, thanks.
Old 03-03-2010, 01:56 AM
Rep: 10 Posts: 5
Thank you for the great advice everyone! I think I'll go for a lower end table saw (~$200 as suggested) and save the rest for a good carbide blade, and I will definitely see what I can find used, as I am in agreement with most of y'all about age=quality in regards to machinery. And thanks for the lead pistnbroke, I will check out that program! I'm anxious, but I'm in no hurry. Extra time spent on preparation seems to be time well spent, in my opinion.
One final question: Although my plans have recommendations for types of wood, I would just like to hear y'all's opinion as to what the best type of wood is for small strip-planking jobs like mine.
Old 03-03-2010, 02:25 AM
liki liki is offline
Rep: 104 Posts: 168
I have also been pondering over what tools are worth acquiring for building a small wooden boat.
The books I have read give the opinion, or feeling, that a band saw and a thickness planer would in fact be a better choice over a table saw. What are your opinions?
Old 03-03-2010, 03:19 AM
Landlubber's Avatar
Table saw is the first new toy, followed by 40, 000 other things.
Novice Looking for Advice on Small Wooden Boat Construction oberhelr Wooden Boat Building and Restoration 6 03-15-2009 10:19 AM
Novice boatbuilder needs varnishing advice. GymBob Wooden Boat Building and Restoration 25 01-25-2008 04:42 PM
advice 4 a novice plz surfdreams Open Discussion: All Things Boats & Boating 0 12-27-2006 06:01 PM
Please help a novice David Moskowitz Stability 4 10-31-2006 09:19 AM
Advice for a novice? Hardtop construction bilgeboy Fiberglass and Composite Boat Building 7 12-19-2005 06:07 AM
