Old 02-10-2004, 11:42 PM
louisiana guest
in need of help
i have 2 30"x 20' pipes if icap each end how much can my cabin weigh? pipe weighs 80 lbs a ft
Old 02-11-2004, 08:41 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
In round numbers,
Area of the end of your pipe, 3.14 * (15 *15) = 706 sq in.
Volume of one pipe, 706 * 240” = 169,646
169,646 / 1728 = 98 cu ft
Displacement of one pipe, 98 * 64 = 6,272 lbs
6,272 – 3200 = 3,072 lbs, after subtracting the weight of the pipe.
If your cabin doesn’t exceed 3,000 lbs with everything included, your floats should be near the half way point. I’m sure someone will point out any errors; I’m still on my first cup of coffee.
Gary
Old 02-11-2004, 03:39 PM
Tom Lathrop Tom Lathrop is offline
Registered
Rep: 10 Posts: 72
Gary,
I misssed out on a lot of math by gazing out the window too much but I think there may be something wrong with the calculation.
Tom
Tom Lathrop
Old 02-11-2004, 05:16 PM
Senior Dreamer
I knew someone would help. I hope I'm closer now. My math is bad even when I'm awake, that’s why it says amateur.
Thanks Tom
Gary
Old 02-11-2004, 07:09 PM
TheFisher TheFisher is offline
Registered
Rep: 60 Posts: 83
One more try :)
Gary,
You're close but no cigar again
Volume = pi r squared h
= 3.14 * (15 *15) * 240 = 169,560
= 169,560 / 12 cubed = 98 OKAY so far
Displacement of one pipe, 98 * 64 = 6,272 lbs Yep!
Displacement of 2 pipes = 12,544
Weight of 2 pipes = 2* (80 * 20) = 3200 lbs.
12,544 - 3200 = 9,344
Total weight may not exceed 4672 lbs to float at the halfway mark.
Unless, of course I made a mistake, which I'm known to do from time to time.
