Old 08-16-2011, 04:10 PM
SRSS SRSS is offline
Rep: 10 Posts: 8
need 40-65' tugboat plans.
Anyone know where i could get some 40-65' tugboat plans? nothing too modern I'm probable going to be using steam power and a big single prop, steel hull, Its going to be used for personal use but i wouldn't rule out making some money with it doing some towing or salvage work... also might add I'm going to be using this ship in the great lakes too!!
Old 08-16-2011, 04:48 PM
Quatsino Boater's Avatar
Quatsino Boater Quatsino Boater is offline
Rep: 10 Posts: 52
if you're serious here is a Canadian Naval Architect firm who specializes in marine transportation including tugs for near and offshore work. Robert Allan LTD. These guys have at least 10 different classes of tugs and literally have hundreds of tugs world wide under their belt.
Link http://www.ral.ca/
tugboat specific link http://www.ral.ca/designs/tugboats.html
Old 08-17-2011, 02:51 AM
Rep: 10 Posts: 8
wow those are some nice tug's!! I don't think they are the kind of DIY kind of tugs i was looking for in a build though, little bit to modern, and probable way out of my budget range lol. I was also planing on using steam power too!!
Old 08-17-2011, 09:35 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
You may want to mention these details (and more) in your original post...
-Tom
Old 08-17-2011, 11:36 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
SRSS....
You need to fill out your question a bit....you know...get people interested.....
What are you going to tow? Where? How much power do you intend on installing? What is the engine (I assume you are building that as well?)? What material and construction method do you intend on using?
Old 08-17-2011, 11:42 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
I'll assume you are thinking of something like this......
Old 08-17-2011, 02:52 PM
Rep: 10 Posts: 8
Yeah i updated my original question thanks for the tips!
Attachment 60092
Yeah something like that nice cutter bow and fantail stern classic tugboat lines . I'v seen lots of small tug plans of that style floating around the net like that but none of the big ones!!
Old 08-17-2011, 03:51 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
This is a hybrid yacht/tug....she looks pretty much like a WestCoast log tower but is lighter and has shallower draft than a real tug.
Old 08-18-2011, 01:36 AM
Rep: 10 Posts: 8
do you have any more info on this tug?
Old 08-18-2011, 02:15 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
See the arrangement below......The lower deck is divided by 3 watertight bulkheads, lazerette aft, engine room midships, and foc'sl with 4 berths and head forward. On the main deck there is a pilothouse forward with two high seats, next aft is an entrance lobby on starboard with skipper's cabin to port, small deck head also on port, and galley with dining area aft. The afterdeck has the towpost forward and room for deck chairs , etc....
Old 08-18-2011, 02:53 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
Tad, nice boat! What's the power, fuel consumption and top/cruising speeds?
Old 08-18-2011, 07:15 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Bataan,
Today new 50' log-towers have 1000 HP, 20'+ of beam, draw 10.5' of water, carry 9000 gallons (imp.) of fuel, and turn twin 68" props in nozzles with 4.5:1 reduction gears. 30 years ago a tug this size would have had a 12v-71 (400HP) with 4:1 reduction turning a 52" prop........
This is not a "real" tug and with the designed draft and keel has room for a maximum prop diameter of about 42-44".... A 6-71 (180HP) with 3.5 :1 reduction will turn a 38" dia. prop, push her at cruising speed of 8knots, and probably get her up to maximum speed of 8.5 Knots.....As you can't currently buy a new 6-71, I would look at John Deere, but this boat could easily handle far larger and heavier engines....Cat 343's are available cheap these days and are a great engine....
8 knots cruising will require about 130HP and 6.25gph, but 7 knots is only 50Hp and 2.5 gph.......
Old 08-18-2011, 08:32 PM
FMS FMS is offline
Rep: 125 Posts: 233
If Tad had not posted such a beautiful and appropriate design already, I would have suggested looking through the Boats & Harbors classifieds at old small tugboats to repurpose http://www.boats-and-harbors.com/
Old 08-19-2011, 12:08 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
The trouble with old tug hulls (if you can find one that's not totally rusted out) is the volume is gigantic to carry the huge machinery and tankage that was required back in the day....substituting smaller machinery and tankage will require a large ballast addition, and why haul ballast everywhere you go?
Old 08-19-2011, 12:28 PM
BATAAN's Avatar
Have to agree with TAD here. This tug was originally steam and over the 121 years she has been afloat has been fitted with lighter and lighter engines, until the bilge is full of many tons of heavy old broken iron castings to keep her near her lines.
In the early days of motor tugs, some were long and lean and have been successfully converted to sail with acceptable results, but still make mediocre motor yachts.
A TugBoat dskira Powerboats 6 05-22-2010 07:56 AM
21' small tugboat plans jackason Boat Design 8 07-22-2008 02:53 AM
full scale plans for 65' sailboat $400,miami,fl. 7393452 Marketplace 0 12-10-2006 05:46 PM
full scale plans for 65' sailboat $400 7393452 Marketplace 2 11-08-2006 10:09 AM
New Tugboat Gallery LHKeeper Open Discussion: All Things Boats & Boating 0 06-01-2005 05:02 PM
