Old 10-09-2008, 02:19 AM
depthofit depthofit is offline
Rep: 33 Posts: 11
Naval project that needs lots of help!
Hi, i am a student doing diploma in marine engineering in Singapore and for my final year project, my team have decided to build a simple catamaran model of about 60 cm and put it under a series of test to best estimate the values for the real one which is 6m and runs on an electric engine.(We are not going to build the actual one)
After some readings and suggestions from another forum, i have decided to incorporate a hydrofoil configuration into my model to increase the efficiency of the model. Since we most likely would not have access to any tank testing lab, we are trying to best simulate those test using other methods. We need suggestions on how to simulate them!! (we already have a basic outline of how the towing test is going to be carried out but we need more suggestions on other tests)
The actual boat is meant to travel in river and reservoir and there are no outrageous wind speed in my country. I hope to get some advise on the type of tests that i can conduct for my model to assess its stability, resistance and other aspects(preferebly a few more components to investigate) under different wind speed and water conditions(I am only naming what i can think of, so pls feel free to suggest). I believe a towing test is a must, what about a wind tunnel test? The conditions of the 2 occupants are important as well.
Regarding hydrofoils, i expect the actual boat to be cruising at 5-7 knots and max at around 10-12 knots. The model will be assessed under corresponding speed. Problem is i have completely no idea on how to build a hydrofoil and i have no previous boatbuilding experience either. The designing work before construction of the model is going to be very tough also. I plan to use balsa wood as the primary material for construction and after which epoxy will be coated to give it a smooth finish and also to protect the wood from the water. Correct me if i said anything wrong. Thnks!
Old 10-09-2008, 02:22 AM
Previous Member
Rep: 0 Posts: 0
yes my boy, you forgot to say PLEASE, and thanks in advance
Old 10-09-2008, 02:24 AM
Rep: 33 Posts: 11
Haha ok. PLEASE. I really hope to learn alot from this forum and this project. Anyway this is my other post at cruisersforum
http://www.cruisersforum.com/forums/...tml#post211891
I am depthofit.
Old 10-11-2008, 04:02 AM
Kay9 Kay9 is offline
1600T Master
Rep: 279 Posts: 615
So what is it EXACTLY you need?
K9
New Tall Ship Project- Need Naval Architect/ Production Manager barefootmark Projects & Proposals 12 10-20-2009 12:56 PM
French Naval Architect looking for project/work YG.Archi.nav Services & Employment 4 05-05-2008 10:54 AM
Floor Replacement Help (lots of it!) Johnny823 Boat Design 0 08-05-2007 11:09 PM
I need a Lead Naval Architect or assigned Project Enginner ESG Services & Employment 12 11-06-2004 10:29 AM
Naval Architect/Project Manager needed Burns Services & Employment 0 10-07-2004 05:56 PM
