  #121
Old 02-24-2013, 12:18 PM
viking north's Avatar
viking north viking north is offline
VINLAND
Rep: 1146 Posts: 1,861
Ha Ha --na too old fer dat me son--more of a string plucker now and none too good at dat eider boy-- --Jarge
  #122
Old 02-24-2013, 06:15 PM
Yacht Designer/Builder
Rep: 3967 Posts: 17,895
Duct tape a palm sander to it and make short work of the job.
  #123
Old 02-24-2013, 09:56 PM
VINLAND
I actually thought about fastening it to the in line auto sander and having a go at it. I still do have an idea in mind when i get to sanding the FRP keel shell that will be taken off the keel male mold I am working on here. Unlike the standard process of building a plug and creating a female mold from which i pull off a FRP keel shell I am going to skip a stage and sand smooth the exterior surface of what would normally be the female mold as the finished product. The result will be less accurate foil wise but if i'm careful in the consistency of my layup thickness I should get it close enough. Good enough for the girls(vessels) I sail with.
  #124
Old 02-24-2013, 11:32 PM
I have a 1/2" sheet sander that I've modified for use with a long board. It has an orbital/in line switch and I use it the in line setting, which cuts faster and doesn't hide the cross hatch pattern I'm looking for.
  #125
Old 02-25-2013, 08:08 AM
VINLAND
Since your qualifications, production levels and customers far out number my past i've no doubt there are a few tricks in speeding up the fairing to be taught here. . Recalling the 4 legged boys having accepted me, I feel confident I can walk up and ring your door bell --Be in touch neighbour
  #126
Old 02-25-2013, 05:42 PM
Yeah, I'm one shy now, we had to put down Ryley, but I still have 4 others as back up. The pit is full grown now and she likes fresh meat, so stop on by any time.
  #127
Old 02-25-2013, 06:29 PM
VINLAND
Forming The Leading Edge In Foam
The foam I used on this foil was a 4' X 8' sheet of polyisocyanurate 2" thick Trade name in Canada IKO Therm. Commonly used in house construction exterior to the roof sheeting when installing cathedrial ceilings. It is impervious to resins and has a water absorbtion spec of 0% by volume . Cost $32.75, 15% GST tax included. The sheet I purchased was a foam sandwich using kraft paper. It's available with alum. foil or fiberglass coatings and a special product of fiberglass reinforced foam. I ripped it into 8in. planks and used a fence on my bandsaw to remove the kraft paper. My plan here is to glue one plank at at time in place and sand shape it using the long board with the 3/4 ply foil noses as guides. I used plain old PL Premium construction adhesive as my glue with a few lead weights along with long screws and flat washers to hold it in place. I let it dry overnight and left the screws and washers remain in place. Next post sand shaping the first foam plank using our made up long board.
The "NANCY G" a surfboat /lifeboat to motorsailer conversion build in progress-dscf2042-2-.jpg
  #128
Old 02-25-2013, 06:35 PM
VINLAND
On second sober thought ---
  #129
Old 02-26-2013, 09:21 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Wood Butcher
Rep: 2489 Posts: 5,300
Sorry for your loss. I suspect the pit(whatis her name?) would find VN a little too chewy for her tastes.
Fracking is good.
  #130
Old 02-26-2013, 03:55 PM
She's (Lucy) pretty tough, so Viking, might be just the beef jerky she's looking for.
Ryley was with us for 12 years and survived 17 - 18, which for his breed is 5 years longer than normal. I don't know about the first 1/4 of his life, but his last 3/4's was good.
  #131
Old 02-26-2013, 05:23 PM
VINLAND
I can see the headlines now "" Boat Unfinished, Builder eaten by the Designers Pit Bull" -- when approaching the office to clairfy an engineering question. Next time I come i'll just drop her off a 175lb. quarter of moose meat, hide on. That should keep her busy for 15 min.
  #132
Old 02-26-2013, 06:00 PM
VINLAND
fORMING THE KEELS LEADING EDGE
Ok back to the task at hand -- Prior to sanding with the long board I marked off both the top and bottom 3/4 ply.foil shaped noses with in 2in. coloured sections following the same patterns. Start with the actual nose of each colouring it the same 2in. either side of center, then proceed with 2in. patterns along each side working your way back. Now as i'm sanding it is a simple matter to keep the long board lined up on the same colours of the top and bottom foil shaped noses which will result in proper forming of the foam to match that particular location on the foils as you work your way around the foils shape. While this is tedious and requiring patience it actually works quite well. Especially so if there are two operators, each dedicated to keeping the long board sander located at their respective matching top and bottom colours. In my case i did it slow and solo. In one of the photos you will see a sanding groove formed in the foam plank. To speed up sanding in the next adjacent colour carefully trim off the ridges with a utility knife.
P.S. In the photos foam plank #1 has been glued in place and form sanded. I am working on foam plank #2 which has been glued(laminated) on top of plank #1.
The "NANCY G" a surfboat /lifeboat to motorsailer conversion build in progress-dscf2054-2-.jpg  The "NANCY G" a surfboat /lifeboat to motorsailer conversion build in progress-dscf2056-2-.jpg  The "NANCY G" a surfboat /lifeboat to motorsailer conversion build in progress-dscf2060-2-.jpg
The "NANCY G" a surfboat /lifeboat to motorsailer conversion build in progress-dscf2063-2-.jpg  The "NANCY G" a surfboat /lifeboat to motorsailer conversion build in progress-dscf2062-2-.jpg
  #133
Old 02-26-2013, 09:51 PM
Screw the dog, drop the moose meat off on me, the hell with Lucy. Until I read your post, I thought the native American was coming out of you.
  #134
Old 02-28-2013, 09:57 AM
VINLAND
I'll bring a few nice thick steaks on my next trip south. My kindergarden layout Kinda threw "you all" off "A". We up north have to add colour ( we even stretch the word out with more letters) where ever possible during winter. Ye have all those colour flashing pretty "birds" flittering around in the forest and on the beach to satisfy your wants.
AHhhh --- The white sands of Daytona will be so enhansed about now, as far as the eye can see. (Old men need (imaginery) love too.
  #135
Old 02-28-2013, 04:44 PM
The azaleas are blooming my friend - spring is here.
1932 Motorsailer "Seaweed" ironbearmarine Motorsailers 0 10-03-2010
09:17 PM
Runs in "high build epoxy" jmac Metal Boat Building 3 03-15-2007
03:47 AM
FSP "fiber spray putty" to build boats pacoblasco Materials 10 12-09-2006
07:02 AM
I Would like to build a rib"looking for mold for it " johndasilva Boat Design 3 06-06-2006
03:01 AM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004
02:03 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
