The "NANCY G" a surfboat /lifeboat to motorsailer conversion build in progress
Discussion in 'Boatbuilding' started by viking north, Feb 11, 2011.
  1. viking north
    Likes: 94, Points: 48, Legacy Rep: 1146
    viking north VINLAND
    Ballast Installation Access Holes
    Today i cut the access holes that will allow work on the keel bolt/ballast cage assembly and installation of the ballast. Don't let the size and number of access holes throw you off. The hollow skeg and fin shells will be completely filled with some combo of resin & stone (100lbs. cu. ft.), resin & lead bits(500lb. cu. ft) or resin & packed lead (600lb. cu. ft.) I have saved and labelled the cutouts and will simply glass them back in place. You will notice some of the volume calculations between stations along the fin. These volumes will help me determine the ballast mixture to both fill the volume and satisfy the weight required in that location to achieve longitudinal balance as per the wonderful, tedious world of "Moments". For me they will indeed be "Moments to Remember," I almost went nuts from weeks of gathering weight and distance info. AHhhh but that's now water under my bridge and filling the "Designer's" boots :D Next phase building the ballast cage.
  2. Yobarnacle
    Likes: 130, Points: 63, Legacy Rep: 851
    good progress.
  3. viking north
    Thank's Yo, as one who well knows, all participation and encouragement greatly appreciated :)----Geo.
  4. hoytedow
    Likes: 400, Points: 93, Legacy Rep: 2489
    Great progress; now if you only had that concrete yardage³.
  5. viking north
    Well now,growing wiser with age --John will need that ramp before me --:D Meaning of course he will figure out a more economical system
  6. viking north
    Hoyt, next trip come during boating season and we'll go to sea. Yesterday took a build break and accompanied John out on the North Atlantic.
  7. hoytedow
    Yeah, we missed boating season by a couple of weeks, didn't we? It gets freaking cold up yonder in your neck of the woods. Thanks for the invite. Will seriously consider depending on availability of opportunity. Maybe try to work in Vinland visit same trip.
  8. Scunthorp
    Likes: 5, Points: 0, Legacy Rep: 11
    Scunthorp Hull Tech
    Great day on the water when I figure out how I will post a video
  9. hoytedow
    Easy: Just post it on youtube and link to it here.
  10. hoytedow
    How goes it?
  11. viking north
    Ha Ha Hoyt, I haven't vacated the living yet but there have been periods where it might have been a desirable break from the ongoing maintenance and running of the B&B plus that sun room addition. So much so we just shut it all down and took a much needed break in the Appalachian Mountains on the West Coast of Newfoundland. Spent a month there, scouted out all the harbors compiling a good log of local fisherman knowledge. Nothing like local knowledge from these old boys to fill in "where the rocks are not" :) And yes of course I walked in the footsteps of the Vikings at L' Ans Aux Meadows. Attached a few mountain scenery photo's to water your appetite.
  12. Yobarnacle
    Hoisting drinking horn filed with coffee, "skoal, Viking"!
  13. viking north
    Yo, How did you know? As per one of these photos the coffee is about ready and the horn cups are hung awaiting use.
  14. Yobarnacle
    I have Viking ancestors also.
    and Sioux.
    Sharp senses.
    Can smell coffee half a continent away, when the wind is right. :D
  15. viking north
    Speaking of sharp senses, one needs them 40ft. up. However there are "view" perks looking both in and out the bay. :)
< catamarn: how to plumb water tank in each hull | Which Stapler to Buy >
  1. Dreamymango
