Old 11-04-2009, 11:53 PM
colfar5033 colfar5033 is offline
Rep: 60 Posts: 51
my russian boat
morning all
things are going well here in africa have cut another bulkhead and have another marked out ready to cut this afternoon .will be collecting some material for frames later this afternoon . manie we discussed that i should try and pave area that i will be building in what if i was to put some of those crusher stones down am running out of space in my garadge so are starting to hang pieces on wall
My russian boat-colin-boat-96.jpg  My russian boat-colin-boat-99.jpg  My russian boat-98.jpg
Old 11-05-2009, 08:02 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,538
I dont like crushed stone because i walked on it for 8 years on the mine, we had an abundance of the stuff so it was everywhere.
It does work to a point and will give a "dry" surface to walk on after rain, but will drive you nuts after a while, dusty when dry.
We had these big CAT 950 loaders that constantly "fixed" our roads and pathways - still lousy.
Building your boat is going to take much longer than you plan or anticipate, and to be surrounded by a **** surface for all that time is lousy.
Rather save the money and work on a grass surface, that you mow once a week and then pave bit by bit as you have money and time.
My 2 cents
Bye bye Folks - off to see the world ~~~/)~~~ :)
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
Old 11-06-2009, 12:10 AM
Rep: 60 Posts: 51
my russian boat
manie
funny that you mention walking on crusher stone had the miss fortune of walking on it yesterday on one of our sites and its kak(not nice). so its back to the drawing board as area in garden is soil no grass
Old 11-16-2009, 09:09 PM
ajlewie ajlewie is offline
Rep: 10 Posts: 8
Hi there Colfar, good to see you already started building the k800. Here`s another build going on in Brazil..http://www.fotolog.com/kavalier/38626850..they made their k800 hull more precisely as per plan..Happy boatbuilding dude!
Old 11-17-2009, 12:36 AM
Rep: 60 Posts: 51
my russian boat
thanks ajlewie
thanks for the link. what sort of changes did you do to your boat
Old 11-17-2009, 01:33 AM
Rep: 10 Posts: 8
One of the major changes I made was the changing of the 8mm plywood bulkheads into 19mm, and then we removed the frames. But in your location, I believe pine wood is abundant. Here is not and if there were available one, they were engineered type, with finger joints and very expensive too. I was planning to use phil.mahogany for the bulkhead frames but it will make the boat much heavier so the use of 19mm marine grade plywood is more efficient IMO. I also changed the centerboard into a daggerboard with a 300kg lead ballast that can be lifted with a winch. the original centerboard design I believe does not have enough ballast to make it self righting..this boat got a tall mast and the chances of rolling or capsizing during high winds were high.I`m still planning to change it back to its original fin keel design but with a heavier fin for more ballast, still on the drawing board for that. Next modification was the boarding flatform I placed at the stern and the steering wheel but later removed and went back to tiller. How`s your build going?
Old 11-17-2009, 01:48 AM
Rep: 60 Posts: 51
my russian boat
ajlewie
pine is easily available here in sa as well as marine ply.was thinking of doing the same with my bulkheads as it takes time to make the frames on bulkheads.
i have cut out 9 of the 15 bulkheads and have framed 5 so going well so far
and have our christmas break coming so will have 3 weeks for building. send some photos of your build if you dont mind its nice to see other boats
Old 11-17-2009, 02:05 AM
Rep: 10 Posts: 8
yeah,,that`s very laborious but of course,that is how it was designed, do it the way it is planned. your doing a good job...if there were pine here, I`ll do the same. .same here,I`m planning to work on the k800 this Christmas vacation, need to repair it, repaint and change/modify the mast..I`m still busy finishing my dinghy build...speaking of the mast,what kind of mast are you going to install? I made a birds mouth mast, so heavy,no available 12.5m aluminum mast here...I will try to lessen its weight by removing the thick epoxy putty, glass and resin my painters applied on it...here`s a link where i post my build then http://pinoyboats.org/forum/viewtopic.php?t=747
Old 11-17-2009, 11:43 PM
Rep: 60 Posts: 51
my russian boat
ajlewie
have been looking at your build and you have done a nice job and liked the video and photos. how long did it take you to build i am planing on an aluminuim maybe second hand or new depending on costs
  #25
Old 02-22-2010, 01:03 AM
Rep: 60 Posts: 51
my russian boat
morning gents
have been a little quiet of late was battling to get marine ply all my normal supplyrs had none and those who had were mad with there prices. its full steam ahead again and have sorted my issue of building area out.am hoping to have bulkheads finished by end march and in building position end april .
  #26
Old 03-11-2010, 11:47 PM
Rep: 60 Posts: 51
my russian boat
coming along nicely now almost a boat
My russian boat-colin-boat-103.jpg  My russian boat-colin-boat-102.jpg  My russian boat-colin-boat-105.jpg
  #27
Old 03-12-2010, 12:39 AM
Manie B's Avatar
Looking good - what glue are you using on the joints - it should be epoxy
all wood should be totally encapsulated in epoxy
  #28
Old 03-12-2010, 01:03 AM
Rep: 60 Posts: 51
my russian boat
thanks manie
have got sp106 that i will use for joints and to encapsulate.
Am putting all bulkheads together and then strip and epoxy the whole thing.
hope i am doing the right thing
  #29
Old 03-12-2010, 11:05 AM
Manie B's Avatar
all ok - just a lot of extra work
but better to be safe than sorry on a first build if you are not 100% sure
  #30
Old 03-16-2010, 03:24 AM
Rep: 60 Posts: 51
my russian boat
To true manie. have 3 of bulkheads to finish and took all others to building
area to see how it fits
My russian boat-colin-boat-111.jpg  My russian boat-colin-boat-110.jpg  My russian boat-colin-boat-109.jpg
Russian Hydro-Foils for filling in commute bottle-necks? Squidly-Diddly Boat Design 5 08-27-2009 12:19 PM
Question for Raggs and other Nordics, Russian, Canucks lazeyjack Open Discussion: All Things Boats & Boating 9 05-23-2007 03:37 AM
Russian Birch Plywood For Interior ? luso Wooden Boat Building and Restoration 0 06-13-2006 11:23 PM
Russian Yacht and Shipyards Yachting Boatbuilding 5 01-18-2006 04:22 PM
