Old 02-05-2009, 06:19 PM
masalai masalai is offline
masalai
Rep: 891 Posts: 6,343
My little piece of peace
The following will document aspects of the construction of my Bob Oram 39'C and to start with here is the intro http://www.boboramdesign.com.au/39-c/ and the profile may look a little like this http://www.boboramdesign.com.au/40-pearl-bay/ but not necessarily so....
Construction is anticipated to commence in mid / late April 2009, build site has been organised and money is hopefully sorted, (who can be certain and confident in these ridiculous economic times)...
building commenced 23April2009 - - http://boboramdesign.wordpress.com/39-c/
chatter on my build progress . . . http://www.boatdesign.net/forums/boa...-new-post.html
Old 02-09-2009, 08:54 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 496 Posts: 1,073
Mas best of luck pal
i read in between the other posts that you have sold your houses - great stuff
Please feel free to ask for advise on epoxy - i know that you are surrounded by experts - but i have done an unbelievable amount of experimentation with marine ply and epoxies, i may just have that little tit bit of advice that you could need to make life easier. I have become very proficient at mixing small batches on a daily basis and my "production line" is actually running very smoothly. I have also learned how and when to clean tools and when and what to throw away - all to be cost effective. I have become quite accustomed to work 4 hours and more every day on my boats, i start at 5 in the afternoon to 9, weekends 9 to 6. Once you are into it, its all ok - just difficult to get started.
I am working like crazy to get my little experimental cat on the water because i have started working and drawing my 12m Cat in all earnesty. I still believe that i can get my "Jarcat" on the water in April - which means that i will start my 12m Cat in May/June 2009. The design and technique that i am following is basicaly a combination of Schionning / Oram / Easy. I am not building a "new boat" or re-inventing the wheel, i am basically taking the features that i like from each and combining them to suit my requirements for single handed setup. I do intend to live permanently on the boat as my family will only be with me when they have leave/holidays as they will all be working and persuing their careers, they have no desire to sail with me.
Are you intending to live on your boat or is it for pleasure only?
Old 02-09-2009, 12:23 PM
Fanie Fanie is offline
Fanie
Rep: 893 Posts: 3,155
Mas, Q.
Why a power only boat ?
Regards
Fanie
Old 02-09-2009, 12:39 PM
robherc robherc is offline
Designer/Hobbyist
Rep: 55 Posts: 431
Fanie,
From his statement that he's building a 39-C (sail powered) with a profile similar to the 40-pearl-bay, I was guessing that he was planning on having sail power, and cutting the cabin to match the 40's profile.
...maybe i was guessing wrong?
Old 02-09-2009, 03:10 PM
Fanie
I don't think that's Masalai that uploaded that web page, he could never be THAT serious...
Regards
Fanie
Old 02-09-2009, 03:26 PM
masalai
Absence? been busy with relocating and stuff, I would like a longer roof aft but if Bob says no then I bow to his wisdom. Sails are twin genoas, one to each bow (so are each bigger than one to midships). No main as the roof there is reserved for solar panels to be set up very last as have an 8kw diesel battery charger in a box up front next to cockpit at the mast...
Electric drive at the moment - the Torqeedo legs are favoured either the 2.0 or the R http://www.torqeedoaustralia.com/Tor.../Products.html and batteries likewise subject to change are the spiral wound AGM style to supply house and motors and nav will be 12v through engine batttery charge system...
Old 02-09-2009, 03:47 PM
Fanie
Clever. Exactly what I'm doing with my cat as well although my mast are going to be aft aft like in aft so they can be taken down easily and the 'genoas' are full size. Makes them much easier to handle too vs one huge monster and centre of sail is lower as well.
Regards
Fanie
Old 02-09-2009, 04:03 PM
masalai
I think you may be oversailed...? there were several images of John Hitches "XIT" on this net (search John Hitch?) - the rig is called a hitch-hiker rig...
Old 02-09-2009, 04:10 PM
Fanie
Nah, less than 32m^2 per sail... It's going to be just right.
Regards
Fanie
Old 02-10-2009, 11:01 AM
Fanie
Why do you think my rig is going to be oversailed ?
So Mas, you're putting a shack and a shed up now... right ?
Regards
Fanie
Old 02-10-2009, 03:11 PM
masalai
Shed is there, just waiting for the boat in it to be launched (a bob Oram 44C with 48V DC "Polar Power" electric drive & genset.... Should be interesting to see performance & fuel efficiency....
Just on your description, with the mast way, way back aft and full sized pair of sails (I presumed "full size" to mean as big as could fit)....
Old 02-10-2009, 03:16 PM
Fanie
You told Bob 'there's the shed, fill er up' ?
On a 10m cat, 2 x 32m^2 sails is too much ? Masts is then at only 11m..
Regards
Fanie
Old 02-10-2009, 03:28 PM
masalai
OK retraction - brain not working, so concede..... - still in "moving house" mode contents from Sunnybank Hills house have absolutely filled new home so WTF, ? where will the stuff from Buderim go ????????
Old 02-10-2009, 03:48 PM
Fanie
Your priorities are mixed up. If you got the boat first then Buderim could have gone on the boat.
Regards
Fanie
Old 02-10-2009, 03:57 PM
masalai
But, but, but, but, sale of Buderim pays for boat..... I think I got it right .... Lovely Lady wants house, and now has got it... Now my turn to get boat, with full approval and blessing.... I think I know which side my bread is buttered ....
vintage piece of electronics? wheresbob OnBoard Electronics & Controls 9 05-01-2007 09:33 PM
2 piece Vs. 3 piece Hulls image691 Boat Design 12 08-07-2005 08:55 AM
Bent Trim Piece mikkyle Fiberglass and Composite Boat Building 3 12-26-2004 09:15 PM
teak and holly plywood piece modunlavy Boatbuilding 1 03-30-2004 09:09 AM
One Piece Shower nit. JohnK Materials 6 07-09-2002 04:25 PM
