#961
| Mas just a little confused this side no mini keels ?? no daggerboards ?? whaaaaaz up ? oops ! or did you forget ![]()
__________________ Bye bye Folks - off to see the world ~~~/)~~~ :) Compulsive Neurotic Manic Depressive, but basically happy :) http://compaxboats.wordpress.com/ http://www.boatdesign.net/forums/boa...ser-27869.html |
#962
| Mini-keels going on later, else no way to get the boat out of the shed, even with removing the sections at the front of the shed, will JUST squeeze it out...
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
#963
#964
| Well, the team have excelled, and exceeded all expectation... The starboard hull could show what can be done, I guess a bit more bog/undercoat and a finish that should look like polished diamond...
#965
| And some more of the deck and of hatch/hold and into parts of the hulls...
#966
| A visit by Bob Oram has helped resolve many concerns and further instilled the dictum "Become paranoid on weight issues" and some more drawings and engineering data in the next month or so - Top secret stuff ![]() , - so be patient and see it when it is built...The team are into the sanding/bogging stuff so - - "nothing to see here, move on now", is all I can offer for the moment... I will be posting images as and when there are changes to report/post... My lovely genset is on the market for AU$11,000 pick up from build site... PM me if you are interested and that will include "first start" commissioning by Wattagan.... I will have to look for a smaller - - by 15cm in height system - - Standby option is to use the 22hp Kubota 6KW system as standby power in our new home as we are installing solar HWS and 20 PV panels for co-gen power.... (Kubota and batteries will mean we can go offline totally if that need ever arises...)
#967
| I'm holding my breath ![]()
#968
__________________ "To be truly challenging, a voyage, like a life, must rest on a firm foundation of financial unrest. Otherwise, you are doomed to a routine traverse, the kind known to yachtsmen who play with their boats at sea... cruising, it is called." Sterling Hayden "Wanderer" |
#969
| Just for being so nice, I went up and took some pictures, (a 20 something km round trip and refuel the car later)... Just 2 of the boat, and one of 2 of my fingers ![]()
#970
| More bogging, then removing most in the sanding process, then more bogging, then removing by sanding then........... here is some of the evidence of the labours of the "dream team"....
#971
| Wow, a piece of cheese and a stick is OK...maybe if necessary to be added a cup of cow's milk...
__________________ $Nothing ventured, Nothing gained$ |
#972
| Decisions, decisions, decisions - - Which images to post? OK, 5 of the bridgedeck area
#973
| Next up 3 of unusual tools (digital scales - wrapped in a plastic bag for protection, mixing drill - not wrapped in plastic, lasts for about 4 to 6 months, and 'disposable' buckets, 700ml 'disposable' cups - to mix in, disposable latex gloves - OHS equipment - or to pretend one is a proctologist - except none of us looks scary enough to play the "Cannon-ball Run" character, - and stuff, then 2 of the boat - diagonally opposite corners...
#974
| G'Day Masalai, Please tell us when you have time, about the Nautical brand epoxy primer undercoat; where from, where used and how. Thanks for the photos, excellent work by the team and great quality images from yourself.
__________________ Tom http://scrumbleproject.wordpress.com/ 'No shortcuts for a vehicle from which you cannot get out and walk' |
#975
| Hi Tom, I will ask Monday...
| vintage piece of electronics? | wheresbob | OnBoard Electronics & Controls | 9 | 05-01-2007 09:33 PM |
| 2 piece Vs. 3 piece Hulls | image691 | Boat Design | 12 | 08-07-2005 08:55 AM |
| Bent Trim Piece | mikkyle | Fiberglass and Composite Boat Building | 3 | 12-26-2004 09:15 PM |
| teak and holly plywood piece | modunlavy | Boatbuilding | 1 | 03-30-2004 09:09 AM |
| One Piece Shower nit. | JohnK | Materials | 6 | 07-09-2002 04:25 PM |
