#721
| Really interested in the fridge..... http://www.google.com.au/url?sa=t&so...P1uFch_Scb4GXQ http://www.myboatsgear.com/newsletter/200915f.asp |
#722
| Electric V outboards After much pondering I have decided to go, once again with 4 strokes outboards. The benefits (at present) far outweight the electric motors. I know of one guy that has spent close to AU100,000 for a Glacier Bay electric system for his 50' cat and he is having tons of electric and electronic trouble. It is true what has been said above that you can find petrol in most remote places, natives all use outboards and scooters, all I need to do is be prepared to carry the fuel aboard as petrol pumpe on the jetty are nearly impossible to find. To do that I will build a dinghy that is a sort of big tank and will carry (slowly) a couple of hundred liters of fuel and will have its own built electric transfer pump. I borrowed a similar setup from a fisherman in Dampier and it worked perfectly. Other advantages I see are:
Lastly, I know I said that before, but on a 39' I would put twin 25HP. A sailing boat only "needs" engines when she really needs them, when you are going into a harbour against strong winds or through a pass against the wind and tide. Differently from diesels, outboards are much more economical to run at 1/2 to 3/4 trottle than at full speed and you have the reserve trust for when you "need" it.
__________________ Keep smiling Stefano |
#723
| Hi Stefano, Any remote chance of some pictures of your boat ? I'm also very ineterested to see how your sails is going to turn out.
__________________ Regards Fanie |
#724
| Stefano, - - - post Fanies request here if you like... boat fan, - - - Fridges are from "Hardley Normal" and standard domestic freezers but 5 star rated efficiency - around Au$450 each and with an external controller on one to make it operate at "refrigeration" temperatures...and at 170+ litres each, BANG for BUCK cannot be beaten... Marinised ones that size would need 4 x "waeco's" at AU$1200 PLUS each ????? - no contest... So here is the root of my conundrum, I have justified an electric galley on the basis that I will have the battery capacity to meet the needs of the Torqeedo's - - and electric outboards because I need the battery capacity for my comfortable live aboard and independent lifestyle ![]() - - - If the rest of the world goes mad and prices for finite commodities like oils go through the roof, - - (for more reasons than just "peak oil" and "economic systems collapse"), - - I will still have mobility and all my comforts![]() ![]() ... Therefore I will sit on the metaphorical fence and be able to go either way until very close to launch date in April 2010.... It is almost 50:50 at the moment... Several things will influence me and they are all a mix of "up-front-cost", "weight reduction", "delivered performance" & "resource independence" related...The Yamaha 25 hi torque are the outboard option at present... but even a pair of 15hp hi torque 4 strokes would be quite adequate...
__________________ building commenced 23April2009 - - http://boboramdesign.wordpress.com/39-c/ chatter on my build progress . . . http://www.boatdesign.net/forums/boa...-new-post.html |
#725
| Sorry Mas, I didn'y mean here... but thanks.
#726
| But I DID ![]() ![]() ![]() ![]()
#727
| Mas, >>>standard domestic freezers but 5 star rated efficiency<<< make sure they have a proper ventilation! Optimal is a duct directly outside. You otherwise heat up the room and the compressors run 24/7. Regards Richard
__________________ Fortior est qui se quam qui fortissima vincit Moenia. |
#728
| Have you had a look at these guys? http://www.solazone.com.au/fridges.htm They are in your area I looked at household 240 volt refrigeration but kept getting told by the "experts" that the lack of insulation would let me down horribly |
#729
Could be difficult , fan driven venting ? |
#730
| No, just sufficient airflow behind the fridge! And optimal directly outside. Thermal flow is enough! Richard Quote:
Richard
#731
Due to the poor efficcency of the inverter + the poor insulation + the heating of the fridge recess, the 240v fridges were VERY inefficient and drain my battery banks quickly, even with 480W solar panels at work. The ice box had 100mm insulation throughout and a thermostat with 7 settings, anithing over 5 started to freeze, so I kept it mostly at 4. It used only 80W when running and it would only run intermittently as it needed. I looked at converting the 240 to 12V and was asked about $600 ea, but the insulation on those fridges is really shit. Richard is right, making the door for an upright fridge is the difficult part. Converting 240v fridges to 12v without improving on the insulation would also prove to be energy hungry.
#732
Would it not be worth the inconvenience and trouble to make them top loading with extra thick insulation to save all that lost energy? I know that top loaders would be hard to load to get access , and the ergonomics aren`t what we are used to ,less convenient to use , but it seems to me that you would not spill all that cold air to the floor every time you opened it , at least ? |
#733
| I am content with the efficiency of these as one will be a converted freezer and at a price of AU$450 is almost at the "disposable" level when compared to the prices for "Marine" ones.... If worst comes to worst, keep the door, individual drawers and build one into the space (still have the same internal volume and 100mm plus for insulated fixed walls), as there is adequate ventilation... They are on the bridge deck.... I am aware of two others who are using modified domestic FREEZERS as refrigerators on boats with no adverse drain on batteries.... I am NOT using a domestic FRIDGE, but a freezer with a 5 out of 5 star rating (most energy efficient) and it uses sliding drawers (not nickers or long-johns)... and adding an electric gizmo between the external power point and the power-plug from/for the freezer to reconfigure and control its operation for even better efficiency as a fridge... Nothing new and it worked OK for me whilst I was on a sheep station where the afternoon temperature in the shade often got to around 55 degrees Celsius (131 Fahrenheit) Thanks all for sharing your concern and experiences.... If they fail, I will advise of same and you are all welcome to chime in and remind me, - - with - - "I told you so" hehehe ![]() ![]() ![]()
#734
| I had wondered what putting 100mm of blue foam on the outer would do and then glue a nice face to the foam. |
#735
| any sheet metal shop can make you any size door case you want add your own insulation and magnetic seal and you have a fridge door |
| vintage piece of electronics? | wheresbob | OnBoard Electronics & Controls | 9 | 05-01-2007 09:33 PM |
| 2 piece Vs. 3 piece Hulls | image691 | Boat Design | 12 | 08-07-2005 08:55 AM |
| Bent Trim Piece | mikkyle | Fiberglass and Composite Boat Building | 3 | 12-26-2004 09:15 PM |
| teak and holly plywood piece | modunlavy | Boatbuilding | 1 | 03-30-2004 09:09 AM |
| One Piece Shower nit. | JohnK | Materials | 6 | 07-09-2002 04:25 PM |
