  #526
Old 09-14-2009, 12:35 AM
downunder downunder is offline
Rep: 30 Posts: 23
Duflex
Standard DuFLEX panels, 1200mm x 2400mm, are
available with rigid end-grain balsa, and structural linear
or cross-linked foam cores laminated with a high
performance epoxy resin reinforced with multiaxial Eglass.
The laminates are finished with peel ply to protect
them from contamination and to reduce preparation of the
surface prior to secondary bonding or laminating.
Core type and thickness, fibre orientation and ply schedule
are based on design, or engineering, specifications to
best meet weight targets, stress and impact loads, and
other design parameters.
  #527
Old 09-14-2009, 03:25 AM
Boston's Avatar
Boston Boston is online now
Rep: 1360 Posts: 3,257
that makes more sense
and the outer skin
the epoxy-resin fiberglass ?
hey Mas
I notice no response to my latest few posts on the oil page
I guess the realities of mining on native lands kinda put a damper on some folks over there
oh well
you were the only one able to speak up and not end up eating crow
cheers
B
edit
I misjudged my mates over on the oil thread
they had no crow to eat
I just get a little over zealous about native american issues
  #528
Old 09-14-2009, 03:40 AM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
Thanks Judy, Next time I will look lots closer - Shows that I keep some distance - - - - the pain in my pancreas on both occasions I do not want to repeat.....
Boston, By the "hit rates", I have a feeling everyone is doing lots of reading and quietly learning - all the "educational" type threads on almost every topic... Pleasing for Jeff as more viewers mean the more he can get for promotional/advertising/sponsorship... I just hope America survives without to much deferred pain... (which is what the political agenda seems to be - the dead dogs should just be quietly buried and some humanely put down like the banks that were bailed out, the FED and those, associated in some way, with either... and most of the surplus US$ toxic stuff.... There is a long way to fall in USA before the toxic stuff can be cleared away permanently and "helicopter Ben" is just adding to the toxic pile as fast as he and his co-horts can...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
  #529
Old 09-14-2009, 06:22 PM
masalai
Ok some news - I picked up my two holding tanks made by Atlas Tanks www.atlastanks.com.au in the small industrial area at Moffat Beach, Sunshine Coast, a bit north of Brisbane... The "standard series" of tanks are all baffled, and fitted with a vent, inlet and outlet of the size and position required by the buyer - all too easy....
My genset is progressing but slowly as Phil has to take his wife for Chemo every second day, so we are praying for her speedy recovery... Phil usually caters for remote power systems have a look at http://www.wattagan.com.au/index.htm...tml&lang=en-us and look around as there are other options that may apply...
  #530
Old 09-14-2009, 09:54 PM
Boston's Avatar
so is the outer skin on that sandwich a fiberglass composite
hit rates
I must have missed that part
were do you find the number of hits on this thing
  #531
Old 09-14-2009, 10:05 PM
masalai
Where all the threads are presented like http://www.boatdesign.net/forums/open-discussion/ on the right hand column "number of views" or for this thread just go to the top of the page and click on the <Boatbuilding> in the blue choices :- Boat Design Forums > Construction > Boatbuilding.... (about 14995 at the moment)...
  #532
Old 09-14-2009, 10:13 PM
Boston's Avatar
no I found it almost as soon as I bothered to do a search for the thread rather than just hit the link I have stored
yikes
there are a lot of people following that thread
  #533
Old 09-15-2009, 06:40 PM
Alan M. Alan M. is offline
Rep: 140 Posts: 176
The structural joining tapes are 750gsm weft triaxial. If it were quad, the warp strands would just add useless weight.
  #534
Old 09-15-2009, 08:10 PM
masalai
Thanks for the heads-up, Alan M are there any more who would care to correct any errors I have made - - I thank God the team know more and better than I
The team are starting on the decks today so maybe some more pictures in a couple of days... The forward chainplates are still a work in progress so herewith - in that (a bit of trimming)...
  #535
Old 09-16-2009, 03:44 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Monetary collapse of US starting on September 30th
Dr Van de Meer predicts monetary collapse of US starting on September 30th By Dr Van de Meer & Benjamin Fulford Sep 11, 2009, 04:47
Email this article Printer friendly page
Benjamin Fulford says Dr Van de Meer predicts monetary collapse of US starting on September 30th
A private but extremely influential silent individual, Dr. Michael Van de Meer is the person predicting a financial collapse of the United States starting on September 30th. That is the end of the fiscal year and the final date for payments the Federal Reserve Board wants to act, but cannot, because it is in a catatonic state, as the leaders of every state in the world is.
There will also be indications on September the 16th, he informed me some ten months ago, “Although September 30th will be the tipping point at which the tree’s fate is determined, the branches will not hit the ground until October 7th and 27th and going on into November,” he says.
Dr. Van de Meer correctly predicted the financial panic that started in September of 2008 (also 10 months in advance) and has made many other accurate predictions.
In a separate confirmation the Chinese Government is no longer entertaining and investing in derivatives, and has declared a Nova-to, meaning they will not be paying the trillions “due” on these illegal instruments. In fact the Chinese are using stronger language saying these criminally foisted instruments are a declaration of a financial war.
Meanwhile, in a significant break in corporate media censorship, the CBS TV program 60 minutes reported that Alan Greenspan, in concert with Bill Clinton and George Bush Senior facilitated in the year 2000, during the middle of the night, the passage of a criminal, highly illegal unconstitutional Bill that created the mortgage and property bubble. The bill allowed unscrupulous individuals in the major Banks and Insurance Corporations such as I.A.G. to hedge bets at a cent to the dollar. This allowed them to create derivatives contracts whose supposed face value runs into the quintillions of dollars (In either the British or American systems that is the next number after a quadrillion!). On September 30th all these fiat numbers created out of nothing will no longer be accepted. Both China and Japan have not said they will only accept gold from America but they have none. Bernanke and Geithner are desperately calling the people who own the gold and asking for some but they have been told they will not get even one ounce.
The bundling of the worthless inflated dollars created a devaluation in the banking system and major banks went down in a domino spiral, the affects of which will be felt for many years around the world. The destruction of the world’s accounting system is so extreme that the tax base of every state and municipal government is strained, some house values have fallen 80%, farmers cannot get credit for parts, seed, fertilizers and water meaning many innocent people will pay, maybe even with their lives.
The Wall Street banksters that own the Fed are being forced to put all their derivatives garbage on the books by September 30th. If they do that, they will be exposed as totally bankrupt.
The new financial system has been embraced by the Vatican, the British Empire and the Dragon family as well as the new Japanese government so it is hard to see how the Fed will be able meet the demands. Also people are now on to them and without secrecy their entire fiat con-job ceases to function.
The new financial system will not allow any off ledger transactions nor any hedge funds or derivatives. Wall Street will not be allowed to - as Dr. Van de Meer puts it - to “do all their contrivances selling worthless air and paper and contrived named instruments that by their very names are comic to the ear. They have been gerrymandered to fool the millions who buy worthless stocks just like little old ladies in sneakers working slot machines”.
The American people who are 4% of the world’s population but consume 40% of the world’s resources have been paying for it all with illusory money. The illusion has burst and there will be a 90 degree fall in the value of money, followed by a lot of hard work as the country rebuilds itself back into greatness. Fortunately, by developing all the new technology that was suppressed by the Feds, the end result of the rebuilding will be a golden age for all. But remember, there will be no gain without pain. However, the Americans are resilient people and will pull together and be a more informed and strong nation once again. First though, they need to seek out this Wall Street crowd; tar and feather them, and run them out of the country on a rail.
http://www.benjaminfulford.typepad.c...09/van-de-meer
Regards
Fanie
Water ! Just gimme water !
  #536
Old 09-16-2009, 07:08 PM
srimes srimes is offline
Rep: 186 Posts: 226
  #537
Old 09-16-2009, 07:11 PM
Fanie's Avatar
Fanie
Mas will like it though
Regards
Fanie
  #538
Old 09-16-2009, 07:55 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Mad Scientist
Rep: 1786 Posts: 2,984
We're being done in by a pandemic of ADD(attention deficit disorder); the media won't cover it and the lawmakers who vote on these things don't even bother to read the legislation before they vote. Too many ticks ride in on the dog.
  #539
Old 09-16-2009, 08:17 PM
masalai
Fanie, I copied it to where it should be but the link is just a blank page????
hoytedow, that is OK as the dog (US$) is actually dead, and helicopter Ben keeps hitting the defibrillator.... - - soon (Dr Van de Meer predicts and Dr Fanie affirmed, as being 30th Sept... {13 days} to wait ) the dog will die as it is starting to rot and smell and beyond redemption...
Back to the topic... The build is progressing with bogging and sanding internally and painting with flow-coat...
  #540
Old 09-16-2009, 08:38 PM
Boston's Avatar
I thought this was the 9/11 page ?
vintage piece of electronics? wheresbob OnBoard Electronics & Controls 9 05-01-2007 09:33 PM
2 piece Vs. 3 piece Hulls image691 Boat Design 12 08-07-2005 08:55 AM
Bent Trim Piece mikkyle Fiberglass and Composite Boat Building 3 12-26-2004 09:15 PM
teak and holly plywood piece modunlavy Boatbuilding 1 03-30-2004 09:09 AM
One Piece Shower nit. JohnK Materials 6 07-09-2002 04:25 PM
