#481
| and other things are crossed too, good luck? Just for Sean, your luck is in as I fortuitously took pictures of my engine room (waiting for the engine (genset)) - the boxes contain plumbing components... and... the "fuel farm" where the fuel will have space and time to replicate and 20 drums for it to do it in ![]() ![]() A false bottom, tiedown points and 9 there (stbd) and another 9 to port and some wherever.... The kubota 722cc 3 cyl diesel with 2 delco alternators to give a peak of 6000 watts to charge the 48V battery bank... The engine will be able to burn coconut oil instead of 'diesel' fuel and the exhaust will smell sweeter...
__________________ building commenced 23April2009 - - http://boboramdesign.wordpress.com/39-c/ chatter on my build progress . . . http://www.boatdesign.net/forums/boa...-new-post.html |
#482
| At least the coconut oil will have a nice tropical smell
__________________ Regards Fanie |
#483
| More images... and this is the 4th attempt (telstra/bigpond persists in falling over - seems a stronger backbone is necessary)... - - (1) Bridgedeck shaping is looking smart and (2) sexily curved, - the (4) forward beam and (3) positioning & chainplates are being organised...
#484
| (1) Raised floor for toilet area to be inserted, (2) hand basin in shower area, (3) one of the 6 cupboards that will have waterproof doors - shower area, (4) Rule pump in the sump for the shower area...
#485
| Well the forebeam is close to being taped into place (first 3 shots, then where the holding tanks will sit, after the slightly sloping floor is fitted...
#486
| The 39C is certainly a nice looking boat. I really like the lines and curves in the first two of the last four photos. Re the forebeam bulkhead, is that an extra piece of 13mm Duflex in front of it, and does it go all the way down to the keel? Presumably it is being strengthened for the forestay/headsail furler...?
__________________ "To be truly challenging, a voyage, like a life, must rest on a firm foundation of financial unrest. Otherwise, you are doomed to a routine traverse, the kind known to yachtsmen who play with their boats at sea... cruising, it is called." Sterling Hayden "Wanderer" |
#487
| Hi Judy, as per standard specifications and yes - I think it is similar to the 44C?... There will be 2 genoas (one from each bow and a blade of about 9sq M midships from just aft of the net area totalling about 80 sq M) about the size of a standard, but on a 12m stick - - I do NOT have a "main sail" aft of the mast and no boom... 5 masthead stays and one set of diamonds is all that is required for the standing rigging... All sails are roller-furled and reefed... In fully laden ready to cruise I hope to be underweight (less than 4862kg)...
#488
| A SPECIAL for Boston and Sean 2 steam engines being overhauled - sheer engineering beauty
#489
| 3 more shots of the steam engines The last image - I am still working out where the sheets and other stuff will go - rough but effective....
#490
| Five images for today are raised floor in P & S aft berths forward cargo hold (to carry the 9 x 25litre containers of either RO derived potable water, or cold pressed coconut oil, the aft cargo holds will remain empty for the present plans... Then there is the forward chain plate construction for the forward stays and roller furled/reefed genoa... Lastly, the curved forward section of the bridge-deck is in position, glued filleted and taped in place...
#491
I cant wait to get my engines and boilers that and secure the shop space thanks for the pict looks great I wonder what the specs on those are and that shot of the reversing lever is perfect most folks dont realize how versatile a steam engine is that you dont need a trany and that they run so slow, you can get a hundred years of life out of em they have huge benefits, are about as efficient as a basic diesel, require almost no maintenance in the closed system steam type Im be suprised if as diesel goes through the roof again if they dont come back with a vengeance thanks again B oh Im going with a v configuration rather than a vertical keeps the center of gravity low |
#492
| http://currentsunshine.com/?cat=2 is using a single Torqeedo electric outboard, I plan for 2, and I am waiting for trials and test runs from Schools Out & another 44C due for launch in April 2010.... Lots of us going electric/PV=solar with diesel genset backup... http://www.torqeedoaustralia.com/Tor...Blog/Blog.html for more info...
#493
| No further data - I went to the shop to get some stainless tube to take the clevis pin (attaching the rigging screw to the chainplate) on my composite chainplates... They had the tube (16mm ID which I bought) and I just drooled on sighting the engines - one used lots of cast sections and the other was manufactured out of flat bar and stuff (I preferred the made one as it seemed to have far more heart put into it than the other using more cast parts)...
#494
![]() the ones I chose arent nearly as pretty but are dam efficient and use mostly off the rack auto parts in the internal rotating assembly my 57 flat top would use 4 of these 125 hp single acting compound steam engines I could get away with 2 but I hate the idea of a owning a gutless wonder so I want it to be able to get up and run from a squall if needs be they are reversible 0 to 1500 rpm I should be able to do about 10 knots at 40 hp but want to hit 16~20 in a pinch these engines are really compact 21x24x14 and light at 250lb each course you have to count the boilers as well at 350 lbs each dry and I need four of em as well your torquido idea is dam enticing I was thinking I would incorporate them into the system for docking maneuvers and emergency power that boat you showed a picture of with the flip down system was really impressive I hate the idea of chopping holes in my hull for bow thrusters course I hate the idea of chopping holes in the hull for anything your build is coming along great Mas way to go dam inspirational thanks for all the pictures B |
#495
| Boston, Your choice, but I cannot see 'four engines and 16 ~ 20 knots' as being comfortable/viable if the nasty weather gets up, - far more to the point, knowing she is well built and can do a comfortable 10 ~ 15 knots safely and with minimum fuss and no unnecessary pounding or bouncing from wave top to wave top? just my 2 cents ![]() ![]() ![]() Start a thread on your build, after all, you have some of the timber ageing and you are doing some of the milling? - "this woodsman is building slowly with love and passion" - seems like a good title?
| vintage piece of electronics? | wheresbob | OnBoard Electronics & Controls | 9 | 05-01-2007 09:33 PM |
| 2 piece Vs. 3 piece Hulls | image691 | Boat Design | 12 | 08-07-2005 08:55 AM |
| Bent Trim Piece | mikkyle | Fiberglass and Composite Boat Building | 3 | 12-26-2004 09:15 PM |
| teak and holly plywood piece | modunlavy | Boatbuilding | 1 | 03-30-2004 09:09 AM |
| One Piece Shower nit. | JohnK | Materials | 6 | 07-09-2002 04:25 PM |
