  #466
Old 09-01-2009, 12:44 AM
masalai masalai is offline
masalai
Rep: 922 Posts: 6,417
A bit time-consuming to get a nice curve like this (1), but worth the effort, - even from the inside (2), and then some edge detail (3) - - silly camera does not like focusing where there is depth of field, but, detail of the hatch to the hold below the aft berth (4), (some filleting work looked a blur but the normal surface was in focus? and the inside of one of the "cupboards" can be seen but flash effect and white flow-coat rendered it not worthwhile posting. - detail on the supports for the berth after the temporary screws were removed and final epoxy to be applied to seal the holes/joins (5)..
my-little-piece-peace-dscn2403.jpg  my-little-piece-peace-dscn2404.jpg  my-little-piece-peace-dscn2406.jpg
building commenced 23April2009 - - http://boboramdesign.wordpress.com/39-c/
chatter on my build progress . . . http://www.boatdesign.net/forums/boa...-new-post.html
  #467
Old 09-01-2009, 01:16 AM
masalai
The next image is of the chainplate, complete with temporarily resident spider (web to be seen) (1), the "hold under the aft berth (2), finger hole to facilitate lifting the under-berth holds' hatch (3), positioning the forward beam for positioning and tapeing into place (4), whenever surplus epoxy mix, these were made (for use in the base of the aft berths) (5)...
my-little-piece-peace-dscn2411.jpg  my-little-piece-peace-dscn2412.jpg  my-little-piece-peace-dscn2413.jpg
  #468
Old 09-01-2009, 01:52 AM
masalai
Tom, I just put about 9 images of the John Hitch "X-IT" in my gallery - enjoy...
  #469
Old 09-01-2009, 03:05 AM
Rep: 541 Posts: 1,419
Mas, There is a Hitch boat at the Brisbane Boatanic Gardens if you want to see another rig, I was working a boat there last week, it has been there for a while.
"We do not know, what we do not know!"
  #470
Old 09-01-2009, 04:18 AM
masalai
Thanks for spotting, but I have had an interesting chat with John Hitch, at Mooloolaba, who answered most of my questions, The "hitch-hiker" is the rig that I am using no main a blade/self tacking storm sail midships forward, and to each bow from the masthead, 2 large genoas, all on roller reefing / furling... Just sorting out the sheets and stays, (where they go without interfering with each other), is giving a bit of concern...
  #471
Old 09-01-2009, 05:44 PM
Fanie Fanie is offline
Fanie
Rep: 893 Posts: 3,228
Eh Mas, it's beginning to look really good.
One Q please, the thing with the hole in it, can't figger this one out. It's either a basin or a head or a foot spa or all of the above
Regards
Fanie
  #472
Old 09-01-2009, 06:08 PM
masalai
The hand basin cut-out "... Shower stall & hand-basin bench being fitted ..." - - I was given a melamine bowl with blue coloured patterns inside and the hole is for it....
  #473
Old 09-01-2009, 06:16 PM
Fanie
Cheeesss... losing your sense of humour there eh. You were not supposed to give the correct answer
If my things work out it is going to be really nice to watch the launch. You better organise a film crew for the event. Imo it is the nicest kick under the butt thrill when she slips onto the water that first time. Man oh man
Are you sure this pile of firewood of your's is going to float ?
Regards
Fanie
  #474
Old 09-01-2009, 06:23 PM
masalai
I havn't finished, I was reading your joke to LL and having another good laugh, - one must do as one is told by a "senior authority - she who must be obeyed - Yes Dear".... So to continue, it is a carefully devised device which will only be explained as construction nears completion... It relates to research similar to this... http://www.theaureport.com/pub/na/29...ld%20in%202009
  #475
Old 09-01-2009, 06:52 PM
Fanie
Ah !!! I get it. You are going to generate your own methane gas that can be used for cooking, that will produce more methane gas for more cooking and that will produce even more methane gas for even more cooking and so on.
So it's a restaurant you're starting and no guest leaves before contributing to the methane process... I can see it is going to boil with activity
Ok, so you're going back to the steam engine also... ? Human powered so to speak
Regards
Fanie
  #476
Old 09-01-2009, 10:25 PM
masalai
Oh dear, I have told you twice now, I will use another term "cold fusion", with a palladium catalytic cathode and electrolyte containing heavy water or deuterium... And I thought you were the technical/scientific one, and that that is what you were working on too?
4+ hours later... 16:52 local time, Sorry Fanie, I forgot to answer one of your questions, Being made of one of the lighter woods, totally sealed in 'glass'-tape/cloth/epoxy, it should float... even if someone tries to fill it with water after turning off the bilge pumps, disabling the security alarms, disconnects the batteries, and feeds the pet, (shark), he is always hungry... Boston is the steam enthusiast and the thought of methane and restaurant together (not a good mix) - - - I thought of another application for the "hole thing" - so that Sean will feel comfortable when he visits (look at his avatar)... Hi Sean
More DuFLEX being delivered tomorrow or Friday so hopefully something to photograph and post on the weekend...
18:11 - 3 Sep 09 - - Surprise.... 5 more then another 5 hehehe... (1) looking aft to aft stbd berth, (2) battery - RO watermaker - inverter and battery charge controllers etc, (3) Stbd looking fwd to laundry, (4) over engine room - Hot water system etc. - to forward sections for chain/anchor lockers and "dorado" air pumps for engine and battery rooms, (5) down to port midships area...
my-little-piece-peace-dscn2426.jpg  my-little-piece-peace-dscn2427.jpg  my-little-piece-peace-dscn2428.jpg
  #477
Old 09-03-2009, 04:21 AM
masalai
Aft berth port, Stern view port, the sump and raised shower floor, looking forward from aft port berth, steps to aft port berth looking from shower area...
my-little-piece-peace-dscn2431.jpg  my-little-piece-peace-dscn2432.jpg  my-little-piece-peace-dscn2433.jpg
  #478
Old 09-03-2009, 05:07 PM
Fanie
I'm soooo jealous. If you are going to make a trip to 'run it in', how about to here so I can also have a spin in it .... ??
I'll give you points for it
Regards
Fanie
  #479
Old 09-03-2009, 05:33 PM
masalai
How about some pure gold and you can have it after returning me home - say - , 11 KG ?
  #480
Old 09-03-2009, 06:22 PM
Fanie
Comma one one Kg ? Taken
Tomorrow and this weekend is a very very important time for me. Cross your fingers and toes.
Regards
Fanie
vintage piece of electronics? wheresbob OnBoard Electronics & Controls 9 05-01-2007 09:33 PM
2 piece Vs. 3 piece Hulls image691 Boat Design 12 08-07-2005 08:55 AM
Bent Trim Piece mikkyle Fiberglass and Composite Boat Building 3 12-26-2004 09:15 PM
teak and holly plywood piece modunlavy Boatbuilding 1 03-30-2004 09:09 AM
One Piece Shower nit. JohnK Materials 6 07-09-2002 04:25 PM
