  #31
Old 03-22-2009, 05:26 AM
masalai masalai is online now
masalai
Rep: 1630 Posts: 7,321
Thanks for the info, I am looking for a local site (Australian) as I am not now sure of the appropriateness of BD.net???
Your "pen & ink" avatar looks quite impressive.... I have bookmarked the new site....
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
  #32
Old 03-22-2009, 08:39 AM
judy's Avatar
judy judy is offline
Oram 44C Builder
Rep: 123 Posts: 42
Googling "free australian blog" reveals a couple of Australian run blogging sites. However they do not specify if they use Australian or overseas servers.
If you use one of these smaller, lesser known sites, make sure you can export/download your content easily and frequently, as it would be awful to lose your valuable data in the event of the site going bust or ceasing to exist.
Of course this could happen with the well-funded popular sites like blogger.com and wordpress.com too, but I consider the risk to be lower. I do however perform daily exports of my wordpress.com blogs to my computer (which also is backed up to a external hardrive). I'd hate to lose our boat project data, especially as we constantly refer back to it when we forget how we did something etc.
"To be truly challenging, a voyage, like a life, must rest on a firm foundation of financial unrest. Otherwise, you are doomed to a routine traverse, the kind known to yachtsmen who play with their boats at sea... cruising, it is called." Sterling Hayden "Wanderer"
  #33
Old 03-22-2009, 10:05 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,538
Mas good for you
The build site is arranged and the ATL order is being cut
very exciting stuff
  #34
Old 03-24-2009, 08:30 AM
masalai
Now all I need is "uncle Bob Bernakie", to stop his manipulating the economy in the USA as it impacts the rest of the world, and he should let things happen as they will.... naturally, - - then I should have a reasonable chance....
A bit under AU53K to ATL for the build materials precut, and some other expenses to be met before start date around 22 April....
  #35
Old 03-25-2009, 01:43 AM
Manie B's Avatar
Mas as you can gather i am a HUGE FAN when it comes to a build project
from some of the other posts i gather that you have premises and the "dream team" all organized
what is your estimated build time = program
with a good team could this be done in 18 months ??
  #36
Old 03-25-2009, 01:58 AM
Boston's Avatar
Boston Boston is offline
Rep: 1360 Posts: 3,257
starting to look like the drivel thread kids
my theory is its as much fun to build it as to sail it
Mas you are going to have a great time
best of luck
B
  #37
Old 03-25-2009, 03:16 AM
masalai
Thanks all for the wishes - The shed is available for 12 months - - so - - that is the build time wanna lend a hand? - I could do with all the help I can get....
  #38
Old 03-25-2009, 06:42 PM
Previous Member
Rep: 0 Posts: 0
Brian
Do ATL provide any proof test data for the specific panels made for your hulls?
Are you intending to do any independent testing?
Rick W
  #39
Old 03-25-2009, 07:19 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Hi guys
Wow Mas, I'm really worried about our main drivel man turning serious all of a sudden
It's a madhouse here on the moment, but I'll be along in a bit.
And 4 5 c, behave yourselves
Regards
Fanie
Water ! Just gimme water !
  #40
Old 03-25-2009, 07:20 PM
masalai
Due diligence will occur - - - I have confidence in the product from the builds I have seen and visited using a method similar to that of Bob Oram, Schionning and others in this region - have a look at the "Scrumble Project" link posted by Judy - there are a couple of shots of the delivery - lots of sheets to join with the assistance or a loan device provided by ATL to facilitate the process.
I have regularly visited a couple of builds, watching the processes as they progress and had a close examination of one that was smashed onto a retaining wall, during a cyclone a year ago - the heavy mono that hooked and dragged anchor to cause the cat to dash against the wall was totalled - the cat was mostly re-buildable but may not be done as a new build would be easier...
  #41
Old 03-25-2009, 07:48 PM
Previous Member
Rep: 0 Posts: 0
Due diligence will occur - - - ...
I will be interested in any independent test data you come by regarding direct adhesion strength and panel bending for the ATL panels.
Rick W
  #42
Old 03-26-2009, 01:59 AM
Manie B's Avatar
Hi Mas does - ATL perhaps have a website with a bit of info?
and to add to what the guys are asking i would also like to know the thickness of the balsa and the thickness of the two outer "skins" of "glass"
for the outer skins are they using an epoxy or polyester?
what weight of glass is in the laminate?
if i win the lotto i will come and work by you for a beer and a sandwich
unless of course YOU win the lotto and buy my plane ticket
  #43
Old 03-27-2009, 01:55 AM
Manie B's Avatar
What would also be very interesting if they have any comparative data on strength.
I would love to know what compares to what eg.
"x" mm marine ply on its own (thick) = "x" mm ATL panel with "x" mm glass and epoxy both sides = "x" mm marine ply (thin) with the same thickness glass and epoxy both sides as the ATL panels
it would be intersting for starters to see in a simple experiment of the 3 pieces - say 1.0 m x 0.1 m supported on both ends - how much weight can it carry before it breaks
  #44
Old 03-27-2009, 01:57 AM
Manie B's Avatar
MOST important of all
what does each weigh per sq meter
  #45
Old 03-27-2009, 04:59 AM
masalai
have a look here - http://www.atlcomposites.com.au/atl_composites/ - what is being asked is for me to compare farts, feathers, ply & ferro-cement? - Well check out the ATL website for their various composite panels, then get a designer, with whom you have confidence and had a look at their products and the damaged boats from severe storm damage by being bashed relentlessly onto rocky shores - I am happy so far.... and 350000 is a sum that is not to be wasted....
End grain balsa is light and has some inherent weaknesses which can be overcome with appropriate engineering in the construction processes. - - One does not go out sailing to "play chicken" with a 20+knot cruise-liner, nor ordinarily build to be literally bullet-proof armoured against a possible pirate attack... Several Oram designs are being built overseas using general construction based on ATL composites as does Schionning and I think Grainger, to name a few.... Don't rely on me I am not a boat building expert - I am confident in what I have seen....
Manie, the balsa composite panels come in various thicknesses and weights of "cloth" - usually made to order...
vintage piece of electronics? wheresbob OnBoard Electronics & Controls 9 05-01-2007 09:33 PM
2 piece Vs. 3 piece Hulls image691 Boat Design 12 08-07-2005 08:55 AM
Bent Trim Piece mikkyle Fiberglass and Composite Boat Building 3 12-26-2004 09:15 PM
teak and holly plywood piece modunlavy Boatbuilding 1 03-30-2004 09:09 AM
One Piece Shower nit. JohnK Materials 6 07-09-2002 04:25 PM
