  #406
Old 08-03-2009, 03:56 AM
masalai masalai is online now
masalai
Rep: 1630 Posts: 7,322
Nup, I would rather a coralline uplift... - - A rising island caused by tectonic plate movement... Far more stable and has "critical mass" sufficient to be readily self supporting for a sustainable lifestyle... My boat is the means of transport...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
  #407
Old 08-03-2009, 07:05 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Sorry for the retarded response Mas, RHP... I don't function well in arctic conditions. As Manie said, the sun is out and there is a little bit of sun. Any change was an improvement.
You guys get stars for appliances ? We used to get them in pre-school IF you behave. Wasn't one of my strong points though I'm sure I might have gotten one or two for consistency though.
Regards
Fanie
Water ! Just gimme water !
  #408
Old 08-03-2009, 07:18 AM
masalai
Thanks Fanie, we are getting that cold weather now, but everybody turned to face north to fart and we blew the bad weather south
  #409
Old 08-04-2009, 08:20 PM
Fanie's Avatar
Fanie
I didn't know one can go more south from where you are.
Regards
Fanie
  #410
Old 08-04-2009, 08:36 PM
masalai
Hey, I am North of Brisbane... hehehe - How many points did you loose to "the phantom" rep poster? - -
Well the build is progressing very nicely, shelving (hull stiffening) and putting epoxy coat on all surfaces, ready to close up as a void, or, flow-coat for shelves/cupboards, or, 2 part paint for the 'wet' areas (shower / toilet / laundry)... tapeing over the filleted joins (epoxy & 700gsm tape) - stuff that takes time and does not show up well photographically...
The Kubota722, was skillfully marinised and supplied by Stewart at (Sea Wasp) http://seawasp.com.au/projects.html is now at, http://www.wattagan.com.au/index.htm...tml&lang=en-us, Wattagan, where Phil is fitting the Delco alternators and controls, to deliver charging capacity to the 48V bank of batteries... The batteries have been moved forward of the mast in the same area as the genset... - - - - - That space, where there used to be 2 head-to-head double berths - smart way to reduce "overnighter guests" as it is NOT a hotel, - - will now house the genset, controllers for engine charging the batteries, 20 Optima D34M batteries, SEAP-48-3K8 inverter, RO watermaker, and some fuel and water tankage...
- - Short list on the batteries is the Optima D34M (20 units) - depending on pricing, - as with 2000W of solar panels on the 48V circuit and 400W on the 12 V circuit. http://www.ausolar.com/products.htm .. all this because the Torqeedo 4.0R from Claude http://www.torqeedoaustralia.com/Tor...alia/Home.html is my choice for powered drive...
  #411
Old 08-05-2009, 12:19 PM
Fanie's Avatar
Fanie
Hull stiffening... WOW ! Kinky bugger eh
So when you've stiffned it up some you are going to start stuffing it Maybe you should fill er up after she's in the water. What will you do if it's too heavy to transport it to the water ? Or is the downhill to the coast steep enough ? And how will you know if it will actually float with all those appliences.
Regards
Fanie
  #412
Old 08-05-2009, 06:17 PM
masalai
By weighing everything before purchasing... Dragging from shed for final fit-out and mini-keels / rudders fitted... Place on the same trailer "Schools Out" used then sneak down the road a couple of hundred meters and wait for the tide to come in - as it usually does - all tooo easy, 'cept it is a Bob Oram design not a 'Snell Easy' one
It is always a case of building where launching does not create unnecessary problems (If you like to do things the hard way, try making love whilst balancing on the top wire of a barbed wire fence)
  #413
Old 08-05-2009, 06:42 PM
Fanie's Avatar
Fanie
This of course just depends how desperate you are. I'm sure it has been done before
I'm going to do a test run with the wet out machine this weekend. The first beam will be hand spun since I had to spend a little f fortune on security stuff instead of buying the drive and motor for it The amount of armed robberies here...
Some pics would be in order, don't let me catch you getting skimpy on the important things
Regards
Fanie
  #414
Old 08-05-2009, 11:01 PM
Boston's Avatar
Boston Boston is offline
Rep: 1360 Posts: 3,257
hey Mas
love the way you mounted the Torquidos
great set up
brilliantly done mate even keeps em out of the way of swimmers and such
best
B
  #415
Old 08-06-2009, 02:29 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,539
Beautifull stuff
i too would be like a kid in a candy store
Sea Wasp
Wattagan
Ausolar
very very cool
Bye bye Folks - off to see the world ~~~/)~~~ :)
Compulsive Neurotic Manic Depressive,
but basically happy :)
http://compaxboats.wordpress.com/
http://www.boatdesign.net/forums/boa...ser-27869.html
  #416
Old 08-06-2009, 03:31 AM
masalai
Errrr Boston, that is not my boat that is Bryan's 46ft "Schools Out", he as gone sailing - I am still building.... Torqeedo's are like little outboards without the engine on top and will be mounted in a similar place but tilt as an outboard does... - - up aft...
Thanks Manie, the crew are looking for another 'Oram Design' project - to commence when mine is launched April 2010...
  #417
Old 08-06-2009, 03:34 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
No No torquidos are rocket like bombs that submarines fire out of the front at ships N stuff.
You know they had them is the war.
  #418
Old 08-06-2009, 03:42 AM
masalai
hehehe, I think we are all a little bored and need some entertainment? Drivel 2?
  #419
Old 08-06-2009, 06:21 PM
Fanie's Avatar
Fanie
Bored ? No man, what you get where ? There's no time, a gazillion things to do.
Have you any more news yet ?
Regards
Fanie
  #420
Old 08-06-2009, 10:18 PM
Boston's Avatar
ah ha
I thought maybe you had suddenly made some serious progress
I still like the set up in Bryan's 46
I saw on the torquido web site that they flip up and down off the stern but thought maybe you had got creative with the mounting brackets
I thought that thing looked awfully done in a hurry
best
B
vintage piece of electronics? wheresbob OnBoard Electronics & Controls 9 05-01-2007 09:33 PM
2 piece Vs. 3 piece Hulls image691 Boat Design 12 08-07-2005 08:55 AM
Bent Trim Piece mikkyle Fiberglass and Composite Boat Building 3 12-26-2004 09:15 PM
teak and holly plywood piece modunlavy Boatbuilding 1 03-30-2004 09:09 AM
One Piece Shower nit. JohnK Materials 6 07-09-2002 04:25 PM
