  #166
Old 05-08-2009, 10:15 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
Hull turned over yesterday afternoon so herewith some new pictures... Only a short week as Monday, everyone was giving birth for "Labour Day".
My little piece of peace-dscn2111.jpg  My little piece of peace-dscn2112.jpg  My little piece of peace-dscn2113.jpg
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
  #167
Old 05-08-2009, 10:37 PM
rasorinc rasorinc is online now
Rep: 678 Posts: 1,127
How about posting your interior layout Mas? Stan
  #168
Old 05-08-2009, 10:45 PM
masalai
Stan, go to the link for boboramdesign, it is there - I am eliminating a lot of "unnecessary stuff", and going for the forward cockpit variation and the forward berths will be for genset and storage...
  #169
Old 05-08-2009, 11:12 PM
judy's Avatar
judy judy is offline
Oram 44C Builder
Rep: 123 Posts: 42
Ah... you have seen the light too!
"To be truly challenging, a voyage, like a life, must rest on a firm foundation of financial unrest. Otherwise, you are doomed to a routine traverse, the kind known to yachtsmen who play with their boats at sea... cruising, it is called." Sterling Hayden "Wanderer"
  #170
Old 05-08-2009, 11:24 PM
masalai
One reason to go for Bobs design rather than try to do my own design - to many engineering problems to sort - why reinvent the wheel when Bobs design is so good.... Also torqeedo drives - subject to satisfactory performance on Niel B's 44C... A hitch-hiker twin genoa on roller/reefers masthead rig, and up to 10KW of solar panels - theoretically, on a hot sunny day I could motor-sail with the engines at half throttle - add 90kg of thrust to sail alone performance...
  #171
Old 05-08-2009, 11:39 PM
judy's Avatar
Oram 44C Builder
Rep: 123 Posts: 42
Hadn't heard of the Torqeedo drives before, so I've been googling. It'll be interesting to see how Neil's trial goes. I cannot find any info on the length of the leg, eg distance between the transom mount and prop centre. Masalai, do you have this figure? I presume you are looking at the Cruise 4.0 R model.
  #172
Old 05-08-2009, 11:48 PM
masalai
http://www.torqeedoaustralia.com/Tor...alia/Home.html Met the guy with Swiss Chris (yellow hull paint 39C) heading north and may be around yours soonish?... Nice and helpful fellow - but product line seems fairly new from memory two options around 60cm and the 4.0 R has a reported 97kg of thrust. Claude lives near where Swiss did his build near Eumundi at the back of Noosa
Found it - a bit more technical data http://www.torqeedo.com/us/hn/products/cruise-r.html
  #173
Old 05-09-2009, 05:50 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
Mechs...
Hello...
When do the mechs. x 2 go in...
What is your main power - etc...
SH...
  #174
Old 05-09-2009, 06:20 PM
masalai
Hi sean, a 10kva kubota based 48v genset set up near the anchor chain locker - forward, charges 2 banks of batteries under each aft berth and the 18kg torqeedo electric "outboards" sit aft in the bridgedeck tunnel - all are designed to be removed for major work and do not go in till fit-out stage, galley is almost domestic in power needs but selected for at least 6 star efficiency rating - the 85l fridge or freezer draws about 300w - 2 or 3 of them - a 2 plate electric hotplate and the list goes on...
  #175
Old 05-10-2009, 03:15 AM
Alex Colville - Still Alive And Kicking
Hello...
Thank the Gods for same - Google his paintings and writings - good for the soul - I believe he was an illustrator during WWI for what became the BBC in Canada...
Looks like you are well on your way - if I can offer any blue collar 'tips on bits' - I would be happy to 'due' same...
I do not believe in electricity though - '**** cannot flow thru a solid'...
Happy high roading - that is where you are now - hard decisions and planning - but you seem to have the brain to push same thru'...
Cheers - I am jealous of you - but I do like my hot baths - on demand...
Mr. Chichester was caught by the above BBC loading Gin onto Gypsy 04 - they needled him - as modern day activist would - Chichesters' reply was - 'any monkey can sail around the world alone - but can that monkey do it whilst drunk' - Cheers Mr. Chichester...
SH.
  #176
Old 05-13-2009, 03:37 AM
downunder downunder is offline
Rep: 30 Posts: 23
Epoxy poisioning
Great thread.
I am in process of researching info for a future build of a crusing cat and gathering info and came across your project.
Note your health issue and wonder if it was related to using epoxy resin. seems some react quite badely to exposure. That is main reason Dereck Kelsall does not recommend it. It is much safer with infusion techniques.
I note you also worked managing plantations near Rabaul, PNG. My best man was Bill Clift who did similar work outside Rabaul. He still works up there today.
Once my cat is built and not by me, 3 years away I intend to cruise and dive PNG extensively.
Keep up the good work. You are not wasting any time.
  #177
Old 05-13-2009, 04:21 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
Very impressive rate of speed of construction going on here. Mind you the hull soon seems to come about. It will seem like ages getting the finishing touches in.
I love the smell of epoxy,-- and fibreglass resin,-- and antifouling all mixed up with deisel and dead fish.
They should market that smell, Ille have a dab under the arms anyday.
  #178
Old 05-13-2009, 04:52 AM
masalai
Hi Downunder, I feel it would be difficult to improve on the Bob Oram designs and support. I should be on the water within a year (I hope and wish - as well as intend, all things being near to as planned)...
Not much visually to report today, bum reinforced and glassed, bogging, fairing and chocolate paint and protective black plastic wrapping (against accidental paint/epoxy etc droppings) applied will see the start on the starboard side mid next week. Monday something may see some images of the pretty chocolate coloured anti-fouling.
Sanctuary Cove boat show on Thursday or Friday (Have a medical appointment with the specialist Thursday early) to get pricing and look over some stuff I will find on show.
I am still searching for a marinised new kubota 722cc or 902cc 3 cyl diesel with a Polar-Power or Fischer-Panda generator delivering 8kW+ to charge 48v battery bank (an ideal - but what else is there?)
As a remote Plantation Manager one does not get around much - socialising tends to be with adjacent plantation owners etc... and I like the "quiet life"... PNG is still a really beautiful place as is Solomon Islands and Vanuatu, but many areas are not really safe for western lifestyles and women (particularly in the remote Highlands) fluency in Tok-Pisin is a real advantage as well as a good understanding of cultural behaviour and dress...
I can recommend the "escorted" Louisades annual expedition from Yorkies (Cairns) and back.
Frosty, is it not time that you considered an upgrade to say a Bob Oram 44'C stretched to 46ft? - - My build site will become available in early 2010 - can be modified (underwater lines) to be power only, as I know you are too old to sail?
  #179
Old 05-13-2009, 11:38 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Yes well, at this rate the boat is going to be finished before he is healty enough to captin the thing.
Nice going Mas. You're really moving along well there.
I should be in the water within a year
Isn't this why we get boats to stay OUT of the water...
Regards
Fanie
Water ! Just gimme water !
  #180
Old 05-13-2009, 05:05 PM
masalai
Bloody typo's... I am working on the perfect sails, I am in the process of training some "bird-catching-spiders" to spin the sails for me and to obey voice commands so if we are ever attacked by pirates I just have to tell them dinner is coming and to attack the pirates and roll them into a "mummy-sack" and hang for their larder - I reckon the boat will look pretty scary too - so we may actually have to go and chase some pirates... - - luckily, as a spirit being, the spiders are not interested in eating me -
masalai is the PNG word for ghost... and "the Phantom" has been done to death and is a boring name - besides "Mr Walker - the Ghost who walks", is not a ghost... Erk! 50000 or so references to "masalai" in google - I'll have to change my name.... Any suggestions? and I have thought of and rejected - wanker, ********, and many similar references which are also over-used?
See, not much to show for Wednesday, bogging and glassing - a bit more bogging and sanding today...
My little piece of peace-dscn2124.jpg  My little piece of peace-dscn2123.jpg  My little piece of peace-dscn2122.jpg
vintage piece of electronics? wheresbob OnBoard Electronics & Controls 9 05-01-2007 09:33 PM
2 piece Vs. 3 piece Hulls image691 Boat Design 12 08-07-2005 08:55 AM
Bent Trim Piece mikkyle Fiberglass and Composite Boat Building 3 12-26-2004 09:15 PM
teak and holly plywood piece modunlavy Boatbuilding 1 03-30-2004 09:09 AM
One Piece Shower nit. JohnK Materials 6 07-09-2002 04:25 PM
