Old 09-25-2010, 08:55 AM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
My first boat building project (Strip planking)! The adventure begins !
Well after some time running around the post office my plans finally arrived!
This is gona be tough since it will not only be my first build, but my first experience with wood, wood work and almost everything else.
To help i have bought strip planking boat construction along with the wonderful help from every one.
I will try to document everything in here and post pics of the build!
So .... my little adventure starts ... along with my dreams of owning a boat i built by my own hands !
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 09-25-2010, 09:05 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Well here is how the boat SHOULD look like ..... i posted them for future comparison
My first boat building project! The adventure begins !-lobster15p5.jpg  My first boat building project! The adventure begins !-lobster15p4.jpg
Old 09-25-2010, 10:37 AM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Good to hear you're finally about to get started. Good luck, and we expect lots of pictures.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 09-25-2010, 11:15 AM
apex1
I am sure that is how she WILL look like in the end!
Have success, luck is not sufficient.
Old 09-25-2010, 11:30 AM
sean-nós's Avatar
sean-nós sean-nós is online now
Rep: 286 Posts: 103
There is nothing like setting out in a boat you build your self, I am sure it will be no prob to you.
Old 09-30-2010, 12:00 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Thanks for the vote of confidence !
I am going through the strip planking book and man i am having problems ... the terms are so alien to me ... im compiling a printed list of boat terms just to be able to have an idea what is what! Its overwhelming !!
I found a company that can cut the mold for the jig using a router cutting machine.
I compiled a list of possible wood to use based on feedback from Bautue and Richard ...
WRC
Afromosia, Douglas fir,,
Sitka Spruce,
Sapele,
Redwood,
Kapur,
Larch,
Guarea *
Mulbery
Mahogany, Khaya in Africa
 close to Mahog.
Pines
More phone calls to chase down suppliers ... i also got 1 KG of epoxy from CMB as a trial. will wait for wood then do some tests as advised in my 6.8 meter boat post!
On a side note, i received the OD16 plans from Beatue as well ... have to say big difference and so much more information much better organization as well.
Old 09-30-2010, 07:59 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
The strength and properties of the woods you listed varies quite a lot (as much as 40 to 50 percent), and in typical strip planking, most of the strength comes from the the fiberglassing of the completed assembly. Therefore I suggest you consider what wood is most commonly available in your area. Some of those woods you listed have to be shipped from a long distance to your location, adding considerably to your costs.
Any reasonably light, clear straight grained wood can be used as long as it bonds well with the adhesives and resins you will be using. Anything and everything has been used in boat building, even reeds and bamboo, so any local quality lumber should work just fine, and save you quite a bit of cost.
Good project, have fun with it.
Old 09-30-2010, 08:06 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
With the research you have done and continue to do, I am sure you will bring this project to a successful conclusion.
Best wishes on your endeavor.
Hoyt
Old 09-30-2010, 09:43 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Thx for the kind words !!I just need to keep on pushing !!
Petros that is sound advice, what i will do is find what is available and choose the most cost effective wood with the best physical properties based on the list above.
So far the favor is with Mulberry (as pointed out by Apex in my other post).
I am compiling a list of wood suppliers and will start calling them next week then i will be able to make a decision.
The shelter i was able to find a supplier that can build a green house metal structure with waterproof cloth (10 meters x 8 meters) at around 1500$.
No welding involved just metal pipes fitted and arced with longitudinal and side enforcement. I will do some research and see if i can get it built myself at a cheaper cost.
Old 10-01-2010, 01:23 PM
liki liki is offline
Rep: 104 Posts: 168
Vulkyn, which design is that, is that Selway-Fisher?
Old 10-01-2010, 01:27 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Selway-Fisher lobster 15 http://www.selway-fisher.com/Mcup16.htm
Old 10-01-2010, 01:51 PM
wardd wardd is offline
Rep: 443 Posts: 925
making it with the cabin?
liberty ships were beautiful
Old 10-01-2010, 01:54 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Based on what assumption are you asking this question? Does a cabin version exist? Or are you asking if i will modify it ?
Old 10-01-2010, 03:11 PM
Rep: 443 Posts: 925
it shows a cuddy cabin
My first boat building project! The adventure begins !-power12p1.jpg  My first boat building project! The adventure begins !-power12p2.jpg
Old 10-01-2010, 03:22 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
That's not the lobster 15 boat mate ... Check my pics at the top of my post ....
My First Boat Building Project superfellow Boat Design 1 04-15-2010 06:57 PM
My Boat Building Project! Michael Tinny Boat Design 7 11-08-2009 06:22 AM
help with boat building project amber Fiberglass and Composite Boat Building 7 05-28-2008 02:54 PM
The Island, an epic adventure of raft building. Quapty Boat Design 5 07-09-2007 04:58 AM
new alloy catamaran project begins Bob Mott Boatbuilding 0 03-04-2006 11:55 AM
