#61
| Ooops! somehow I got the idea we were discussing a canoe. Must be my obsession confusing me! For that boat and those conditions you should definitely glass it. It is outside my area of experience to advise further but the notes on Birch still apply. If there is real danger of holing her, buoyancy chambers will get you home . . .
#62
| Yah sorry i was going for that then my friend pulled out so im back to OD16 Yah just need feedback in regards to the epoxy situation ! ![]()
__________________ The Mummies Dummy guide to boat building stuff!!! "All of us could take a lesson from the weather. It pays no attention to criticism." "Learn wisdom when you can its gona help you out some day in your life" |
#63
| I just sent you a pm with a contact for a good supplier of ep resin and glass fabric that I did business with many times. Just in case you cannot get reasonable stuff locally in Egypt. Fell free to ask if you have problems with his (german) website or need advice on adequate systems or send him an email and ask him for possible resin/hardener combination (i would suggest a fairly slow hardener for the temperatures down there). |
#64
| Birch is not very resistant to decay at all, even worse than the pines, or at least most of the pines. There are a rare few instances where I'd recommend a Doug fir product but its a common ply material and it has better decay resistance than Birch, which isn't saying much. Thats assuming your only considering rot resistance, checking is an issue with Dougy as is splintering and poor finishing characteristics. best of luck B
__________________ I am skeptical of the deniers diatribe |
#65
| How far along are you? Vulkyn - How far along are you as you posted this 9/10? I'd love to see pics!! ![]()
__________________ Jess Hull http://www.AhoySailor.com |
#66
Details are in the following thread ![]() My new baby! 6.8 Meter fiber over wood fishing boat !
#67
#68
| Right !!! Squeezed my brain cells for some much needed comparison for epoxy basic properties, although there is a lot more this at least gave me an idea where i should be headed. I unified all to Kg/cm2. Now its very clear that the CMB solution is not an option at all. It seems that dow's 331 is as close to the properties at it gets. PEC has unusual tensile elasticity as compared to others but since i opted to use west as the bench mark 331 is in the normal range. Now if there are more properties any one know i should be aware off please pass it on !
#69
| Again another snag, DOW can only get me a container full (thats well over 17 tons of epoxy !!!!!!) and they do not provide curing agents either ... So back to square one with an epoxy solutions "sigh"
| My First Boat Building Project | superfellow | Boat Design | 1 | 04-15-2010 06:57 PM |
| My Boat Building Project! | Michael Tinny | Boat Design | 7 | 11-08-2009 06:22 AM |
| help with boat building project | amber | Fiberglass and Composite Boat Building | 7 | 05-28-2008 02:54 PM |
| The Island, an epic adventure of raft building. | Quapty | Boat Design | 5 | 07-09-2007 04:58 AM |
| new alloy catamaran project begins | Bob Mott | Boatbuilding | 0 | 03-04-2006 11:55 AM |
