| Moth rudder foil trim tab adjustment High there I am currently working on a foiling moth and need some assistance with the control system for the rudder trim tab control. Where the control rod exits the top of the rudder foil how is this linked to the tiller extension and what is the degree of rotation of the tiller extension in relation to trim tab angle change. Also how much load does this system see |
| Moth rudder flap control You might check with John Ilett at www.fastacraft.com to see if maybe he'll sell you the components. Also check the Moth forum on the Australian Moth site. -------------------- This may answer your questions; if it doesn't post them on the Aussie Moth forum under "Hydrofoils": Australian Moth Class Association :: View topic - Rudder twist grip Address:http://www.moth.asn.au/forum/viewtopic.php?t=256 |
| A guide to trim tab self-steering system | Eric Again | Sailboats | 0 | 03-01-2006 04:59 PM |
| Keel Trim Tab | mojounwin | Sailboats | 6 | 09-10-2005 11:26 PM |
| Shallow draft rudder foil-wild | Doug Lord | Sailboats | 0 | 08-28-2005 05:38 PM |
| trim tab modification | manunk | Boat Design | 1 | 06-21-2005 09:06 PM |
| rudder foil selection | Hravn | Boat Design | 11 | 04-18-2005 02:52 PM |
