Old 12-27-2003, 08:27 PM
aguest aguest is offline
Rep: 10 Posts: 13
mold maintenance
Am I correct here? I have been repairing some bad places in my mold. I have applied some putty and sanded , got the area fixed. I have now sprayed tooling gelcoat. I go 400 - 600 and then buff with compound? Will this get me the really great shine? Should I wet sand or dry? Any other suggestions would be great. Ricki
Old 12-28-2003, 11:57 PM
Rep: 1397 Posts: 7,215
Go to at least 1000 for a good finish.
Old 12-29-2003, 10:43 PM
Rep: 10 Posts: 13
Wet sand or dry? Should I use a DA or by hand. Your help is much appreciated! Ricki
Old 12-30-2003, 05:32 PM
If you use a DA, pick a small orbit one. The large orbit sanders leave too many swirls.
Old 05-19-2006, 12:03 PM
Russ Russ is offline
60 year plastics veteran
Rep: 17 Posts: 47
Right on,
There is a material called mold sealer and polish. I think both Maguires and TR make one. It in buffed in and fills the pores created by the sanding.
Old 05-19-2006, 05:34 PM
Rep: 95 Posts: 462
sand the mould to 800 then use a fast cut compound to remove any sandind marks u may have to do this a couple of times,then use a finshing compund to clean up and fine scatches
Building a Mold and Laminating Schedule Cpt Albert Fiberglass and Composite Boat Building 6 05-26-2006 05:57 PM
injection aided mold release JV_Comp Fiberglass and Composite Boat Building 6 01-16-2006 08:41 PM
Direct female mold construction... Brant Williams Boat Design 5 02-20-2005 08:19 PM
Lifeboat mold wanted Antonie Bogert Boat Molds 3 01-19-2005 03:22 PM
Design to fit a mold?? Bill Staff Boat Design 2 12-06-2004 04:10 PM
