Old 10-15-2008, 01:20 PM
dpurcell dpurcell is offline
Mold framing with infusion and post cure
I am a newbie to the forum here and have done numerous searches to try and find the answer to my question to no avail. So here it is, what is the best framing material to use for a 18' X 6.5' X 2' boat hull mold that will be used with infusion and post cured to 180 F? I have heard that steel poses a problem since its expansion differs from fiberglass, so I guess my question really is more, will wood stand up to the addittional demands of the infusion and post cure process? The mold will be made from iso PE with an HDT of 225 F if post cured so that should be OK.
Gel Coat Cure - teewhy Boatbuilding 15 06-09-2008 10:25 PM
Will Polyester resin eventually cure fully if applied below 60 degrees? sbklf Fiberglass and Composite Boat Building 13 12-16-2007 04:48 PM
Plug Construction and post cure. ClarkT Fiberglass and Composite Boat Building 3 08-19-2005 01:37 AM
Large Post Cure Oven ClarkT Boatbuilding 2 04-16-2004 12:19 PM
cold mold VS Infusion>>strength/weight/cost compwest boats Materials 0 03-11-2004 12:23 PM
