| ASM, i have built 17 boats with epoxy/fibereglass, over wood. In my opinion, and it's only MY oppinion, you should use the thickness of wood specifide by the designer. Too thick becomes harder to fasten, and tends to make the seams not fair out well, too thin tends to let the pannels flatten between the frams and again loose fairness. Also I like to pick good looking wood because at one point when you look at it your going to be tempeted to varnish not paint. Hope this helps Dennis |
| HI Marcel As up till now, no building here. Would love too, but time, money and space holdme back...and too many designs to choose from. I see you are from the Netherlands too! drop me a line, might be interesting to devellop common knowledge or something . |
| Hi ASM, I tried to send you a direct message through your profile, but you've blocked that option. Could you send me a mail through my profile, then I can respond by e-mail. Kind regards, Marcel (I am Dutch, but writing English here out of courtesy to other readers) |
| minimum size steel? | zeljkomrsic | Metal Boat Building | 10 | 10-04-2006 03:05 PM |
| Minimum coaming height | fede | Boat Design | 2 | 01-04-2006 10:44 AM |
| Minimum practical thickness of aluminium? | Raggi_Thor | Metal Boat Building | 5 | 12-17-2005 06:52 PM |
| Thickness of Plywood for a canoe. | Panos_na | Boatbuilding | 5 | 06-21-2005 06:45 AM |
| Minimum wire size | arjan | Electrical Systems | 9 | 02-19-2005 09:49 PM |
