Old 04-26-2004, 04:32 PM
gngraham gngraham is offline
Rep: 10 Posts: 2
MDO Plywood
Does anyone have any experience using MDO Plywood? I am having difficulty finding quality exterior grade plywood in my area, but everyone seems to have MDO. Anyone used it on a hull?
Old 04-27-2004, 12:13 AM
Rep: 1397 Posts: 7,215
Chris craft used it in all the SeaSkiffs. It works fine above the waterline.
Old 05-05-2004, 12:08 AM
bsandifer bsandifer is offline
mdo
I built a basic hull in 1999 using mdo, and I've been very satisfied. It has never checked or separated, and I use simple exterior latex as a coating. It's spent plenty of time in salt and freshwater. I can find all the good exterior ply I want in the area but not mdo. Sure envy you. George Buehler notes that Chris-Craft used mdo in many boats built in the '50s, many of which are still in use.
Old 05-05-2004, 04:58 AM
Rep: 2891 Posts: 8,795
MDO satisfies the APA (American Plywood Assoc.) marine requirements and usually carries that grade from them. Not all MDO is created equal, I've seen some real good stuff and some pretty marginal stock over the years, so shop carefully and you'll do okay.
I use the stuff all the time and like it. There was a time when there was a big difference in pricing between it and other more traditional marine grades, but that's changing. I just got 12 sheets of good 1/2" BS1088 Doug fur out of Miami at 20% less then I'd been spending for MDO and this is better stuff, so . . .
MDO on the bottom is okay in some applications, but it depends on the construction methods, the strength its providing the design and the amount of warping you'll need to do getting it to flow around the hull. If the planking requires a lot of twist, you may find a better quality marine grade ply the way to go. You'll have less breakage and it does seem that MDO has more flaws and voids then the higher priced stuff, which is where you'll run into trouble when bending.
My Sea Skiff (27' - 1960) was replanked and then sanded heavily before I got it. They used Doug fur and the topside planks look like a washboard. I'm slowly smoothing them out, but MDO would have saved a lot of this work in the first place. Replanking would have almost been worth the effort, but I'm getting real good at smearing on the filler, just so as to not require to much sanding.
Old 05-05-2004, 04:11 PM
8knots 8knots is offline
A little on the slow side
Rep: 349 Posts: 266
looking for MDO
When in search of MDO Shop your local sign supply warehouse. We stock it by the skid. PAR has a good point as the quality of the stuff has declined badly over the last few years. When I started painting signs 15 years ago the stuff was mahogany 7 plys for 1/2" very stable and rarely warped. Now the stuff I stock is 5 ply fir, full of voids and 50.00 a sheet..... I would urge you to get the G2S (good 2 sides) this helps the warp factor as both sides will deal with moisture at the same rate. If your looking to knock together a skiff to get on the water with an A- finish you cant go wrong.
places to look...
east coast Beacon Sign supply
mid west Midwest sign supply
Denco sales
Pacific NW Sun Supply
Hope this helps a little 8Kts
Old 05-06-2004, 09:47 AM
Rep: 10 Posts: 2
Thanks to all for the feedback. Although I have already moved forward on this boat, I think I will use MDO on the next.
How bad do you have it when you have not even finished the first boat yet and you are already planning for the next?
Old 05-06-2004, 09:26 PM
Quite normal . . .
Use of plywood for internal structures RubinB Fiberglass and Composite Boat Building 1 08-19-2005 11:59 AM
Boatbuilding plywood rdbct Wooden Boat Building and Restoration 3 02-05-2005 06:12 PM
mahogany marine plywood structure? blackspot Materials 13 10-06-2004 09:39 AM
Plywood specs from the user point of view amitk Materials 0 10-04-2004 12:13 PM
plywood - advantage of greater number of layers? Materials 2 02-18-2003 11:36 PM
